battery drain help!
Oldboybob
battery drain help!
Post by Oldboybob » Fri Jan 17, 2014 3:52 pm
Hi all does anyone know of any problems that could cause battery drain after a glow plug change? The glow plug rail is NOT touching earth I have already checked this. Any advice greatly appreciated
winchman
Re: battery drain help!
Post by winchman » Fri Jan 17, 2014 6:36 pm
Put a test lamp or meter on the glow plug rail and make sure its on and off at the correct time, I have known the relay to stick on but on some Peugeots if a temp sensor fails it keeps the glow plugs on for ages after the engine starts and burns the glow plugs out.
I woul also check the obvious stuff lights on, little invertyer left plugged in etc
Post by Bob » Fri Jan 17, 2014 7:54 pm
Side door not fully shut will leave the light on.
Oldboybob
Post by Oldboybob » Sat Jan 18, 2014 4:27 pm
All sorted now thanks, it was a dodgy glow plug relay :D
Post by Bob » Sun Jan 19, 2014 12:10 pm
Well done. :D
Post by mikeonb4c » Sun Jan 19, 2014 6:19 pm
Oldboybob wrote:All sorted now thanks, it was a dodgy glow plug relay :D
Excellent. Just to check, was this the £10 NGK relay?
Oldboybob
Post by Oldboybob » Sun Jan 19, 2014 11:56 pm
Yes it was
