Central locking
Graham
Central locking
Post by Graham » Fri Jan 17, 2014 8:50 am
The central locking no longer works on either door on the passenger side drivers door is still ok .Any ideas
Re: Central locking
Post by Bob » Fri Jan 17, 2014 10:00 am
Central locking probs can normally be traced to the loom where it goes into the driver's door, but I've not heard of it affecting only the N/S doors before.
ParkerNorris
Re: Central locking
Post by ParkerNorris » Fri Jan 17, 2014 12:04 pm
As standard, I believe, the central locking only works on the drivers door...
Paul & Lara
It's 'Our' Bongo; not his, not hers...
Re: Central locking
Post by Bob » Fri Jan 17, 2014 2:18 pm
ParkerNorris wrote:As standard, I believe, the central locking only works on the drivers door...
See what you mean, you're right.
Using the locks on the N/S or rear doors doesn't operate the others.
Graham
Re: Central locking
Post by Graham » Fri Jan 17, 2014 6:12 pm
Central locking I can only open passengers doors by either using key directly or lifting latch on inside of door so this means I have to reach across from drivers seat or use key on all doors
Re: Central locking
Post by Northern Bongolow » Fri Jan 17, 2014 7:49 pm
sounds like your drivers door wiring loom has bust/split.
this will affect your central locking and your mirror as in your other thread.
Re: Central locking
Post by Bob » Fri Jan 17, 2014 7:52 pm
See above. :wink: :D
Re: Central locking
Post by Northern Bongolow » Sat Jan 18, 2014 9:17 pm
