Leaking skylight in AFT, suggestions as to best fix?
shedfred
Post by shedfred » Sun Jan 05, 2014 11:37 pm
Yes it has rained a lot recently. Found my bongo very damp inside on the folded tent and the roof fabric soaking. Water sat n the channel around the fixed skylight has seeped inside. I wondered if there was a good way to fix this. Is the skylight removable? Anyone else already fixed similar problem?
Thank you
Re: Leaking skylight in AFT, suggestions as to best fix?
Post by Simon Jones » Sun Jan 05, 2014 11:49 pm
Welcome to the forum. The skylight is bonded into the roof using the same type of adhesive that windscreens are fitted these days. An auto glazier should be able to sort it out for you. I seem to recall the tech manual has a better diagram, but these may help:
http://lushprojects.com/bongopartsmk2/c ... 1of02.html
Short term, you could slap some silicon sealant around the joint, but it's worth getting it repaired properly.
the laird
Post by the laird » Mon Jan 06, 2014 12:22 am
If your having trouble to get it done as Simon s recommended there's a solution called sikoflex it's a strong bonding agent but also repels water you can obtain it on ebay but windscreens shops are the best answer
2newbies
Post by 2newbies » Fri Jan 10, 2014 7:24 pm
After just reading your leaky roof problem.......mine's doing the same, soaking wet roof fabric and tent..I would like to hear how you got on with it....I'm considering using a T shaped rubber seal to fit in the channel around the roof light.......any thoughts......cheers Paul.
Post by g8dhe » Sat Jan 11, 2014 12:03 am
Are you sure its not just condensation dripping off ?
2newbies
Post by 2newbies » Sat Jan 11, 2014 6:11 pm
Hi...I don't think so...the head lining is very damp....
shedfred
Post by shedfred » Sat Jan 11, 2014 9:59 pm
Thank you for he suggestions thus far. First I will try my local trusted Garage to see if they will refit the sunroof. I don't know if that is possible without breaking the existing one. I had though about simply filling the channel with silicone sealant. That will be the fall back option.
2newbies
Post by 2newbies » Sun Jan 12, 2014 12:30 am
hi....That's a option I'm considering,just ran some duck tape over the channel for the time being....
Post by mikeonb4c » Wed Jan 15, 2014 9:52 am
shedfred wrote:Thank you for he suggestions thus far. First I will try my local trusted Garage to see if they will refit the sunroof. I don't know if that is possible without breaking the existing one. I had though about simply filling the channel with silicone sealant. That will be the fall back option.
Its a bit specialised for a local garage maybe, unless they have done stuff like that before?
ELZE
Post by ELZE » Wed Jan 15, 2014 10:46 am
would not bother with a local garage...no oily bits/ I would use a good bodyshop or sunroof fitter but not before giving it a go myself. There are some good waterproofing products off the shelf that would probably do and only cost a few quid.
Thats my sixthpenneth anyway
Post by mikeonb4c » Wed Jan 15, 2014 11:00 am
ELZE wrote:would not bother with a local garage...no oily bits/ I would use a good bodyshop or sunroof fitter but not before giving it a go myself. There are some good waterproofing products off the shelf that would probably do and only cost a few quid.
I agree. Willingness is no substitute for competence here.
helen&tony
Post by helen&tony » Wed Jan 15, 2014 11:39 am
Silicon will probably fail in the sunlight...I would get some old style windscreen sealant like "Sealastic", and I agree with the "T" shaped seal, but press it into the Sealastic....tape it down well, and leave it for a few days before removing the tape....
Post by teenmal » Wed Jan 15, 2014 11:51 am
791 Silicone Water seal is good for that type of job, it even wards off Evil Spirits. :lol:
helen&tony
Post by helen&tony » Wed Jan 15, 2014 3:28 pm
That'll be no good to the Bongo Crowd....we like-um evil spirits...and a bit of evil cider, too!!! :lol: :lol: :lol: :lol:
