hi guys last night at 1am i decided to move the bongo up against the garage door for security and took key out and carried on running.
its done it a little bit in the past but this time woulnt stop at all.had to remove fuel line!
sounds like fuel shut off,as not seen a turbo timer anywhere.
any ideas where it it? and is it a matter of just change it?
fuel shut off valve?not sure where it is
- helen&tony
Re: fuel shut off valve?not sure where it is
Presumably it shuts off when working normally by having power to it disconnected.
Do they ever respond to repeated application of power followed by removal of power, or is a tap with a plastic mallet a possible temporary cure?
The location of the solenoid is probably worth wising up on in advance now that many of us are driving fairly old Bongos.
Is removing the fuel filter an acceptable tool free way of stopping the engine, or does that introduce priming problems for any restart?
Frank
Frank
They flew, I took up naturism
You can get fuel shut off valves on ebay for £40 - £60 (depending on diameter of fuel line) that are electrically operated.
One of these put in the fuel line and wired to only be on with the ignition (take care, some wires that are live with the ignition go dead when the key is twisted to the starter position) should sort you.
You should be able to get a new Fuel stop solenoid from your local auto parts store for under £20.00.
Mazda part number 093324300b
Bosch 9461612134
Mitsubishi MQ906099
They may use different manufacturers but should be able to cross reference the unit.
Good luck
Bosch 9461612134
Mitsubishi MQ906099
Good luck
Thanks guys!
