Injector pipes
- helen&tony
Injector pipes
Is there much movement in the injector pipes?, and can I just remove the 2 small clamp nuts on the manifold, bend the pipes out of the way whilst I remove the EGR pipe, and bend them all back into place without damaging anything?
I seem to remember on a previous diesel that it was possible...but I believe they were copper.
The EGR is blanked, but I want the pipe off as I want the hole on the inlet elbow for something
Thanks in advance
Thanks in advance
Re: Injector pipes
It is not advisable to Bend Old Metal injector pipes as they can be very easily Fractured, best to disconnect from the pump and the injectors a Move them.
Good Luck.
Good Luck.
- helen&tony
Re: Injector pipes
That's what I had thought, considering the pressures....trouble is getting new glands / olives!!!
Re: Injector pipes
You would have to be extremely unlucky if you had to replace any part of the injector pipes after removal unless you damaged them.
Make sure the nuts screw on several threads by hand before you use a spanner.
- helen&tony
Re: Injector pipes
I always ensure they're on right....It's my willing
assistant that I call upon if I want anything cross-threaded....and I NEVER allow anyone else to put spark-plugs in an ally head....
Cheers, Rita...That's tomorrow sorted....It's 0 degrees outside, and the Bongo engine is painful to touch with my hands...
That task will take an hour with stops to warm up
Re: Injector pipes
Make sure you put the wee brackets back on as they stop the pipes fracturing with the engine vibration
- Simon Jones
Re: Injector pipes
I've got a spare set in the unlikely event you have any problems.
- helen&tony
Re: Injector pipes
Thanks, Simon...I expect the only problem will be undoing them...I am not keen on open-ended spanners on old nuts, especially when they are at an angle.....I may end up sawing the pipe off in bits....LOL.
- helen&tony
Re: Injector pipes
What an easy job that was!!!!...undo all the vacuum solenoids, fiddle the pipes undone at the pump end...undo the vacuum metal pipes, carefully remove the nuts on the injectors...oh....I should coco!!!!!!!!.....approximately 30 seconds ....2 cuts with the recipro saw.....
