Jump starting a Bongo
warriorsteve
Post by warriorsteve » Wed Dec 18, 2013 11:04 pm
Hi everybody, first post and looking for some help please.
I stupidly left my interior lights on and my battery has drained almost flat. Ignition lights all fine but not enough power to start the engine.
Now then, I'm certainly not technical minded but I do know how to jump start a vehicle. Or thought I did until today!
Using 25mm booster cables from my 1.8 Mazda saloon to my 2.5 diesel bongo.
Nothing doing even after 20 minutes. Still scratching my head, what have I missed?
Thanks in anticipation guys. Steve
scanner
Re: Jump starting a Bongo
Post by scanner » Wed Dec 18, 2013 11:11 pm
What are you connecting & to where?
I.E. If your Bongo has 2 batteries, which one are you connecting to?
Is the other car a petrol? If so battery might not be up to starting a bigger diesel?
Post by Bob » Wed Dec 18, 2013 11:15 pm
Can you put a charger on it overnight?
Have a Google around for correct jumping technique, nothing complicated but can save stuffing the electronics on one or other car.
Possibly if Bongy's battery is completely flat it could be dead, possibly take it to auto sparks or garage to get it tested?
Good luck, and welcome aboard.
winchman
Post by winchman » Thu Dec 19, 2013 6:17 am
Are you sure its flat?
Could be a starter motor circuit issue
briwy
Post by briwy » Thu Dec 19, 2013 11:32 am
I assume you have got the engine running on the car??
Post by mikeonb4c » Thu Dec 19, 2013 3:18 pm
Weird, was sure I posted but it's not showing. I had this problem and faulty old jump leads proved to be the problem, even though they looked fine. A new set of heavy duty ones and all was ok.
dunslair
Post by dunslair » Thu Dec 19, 2013 4:50 pm
mikeonb4c wrote:Weird, was sure I posted but it's not showing. I had this problem and faulty old jump leads proved to be the problem, even though they looked fine. A new set of heavy duty ones and all was ok.
:lol: :lol: :lol: It is showing.... but just how much relevance it has to changing a rad I'm not sure!!!! :wink:
Post by Bob » Thu Dec 19, 2013 6:31 pm
If you took a really long time doing the rad the battery might go flat. :lol:
cmm303
Post by cmm303 » Fri Dec 20, 2013 12:58 pm
I left lights on and killed the LB. With Fuse 1 (?, from memory) off LB, I think this upset the ECU. Ended up recharging both LB and SB (to be sure) separately before it started and ran without warnings flashing.
Chris with BertieB
Post by mikeonb4c » Fri Dec 20, 2013 3:33 pm
Doh! I blame the smartphone :lol: 8)
Post by Bob » Fri Dec 20, 2013 8:29 pm
warriorsteve wrote:Hi everybody, first post and looking for some help please.
I've got to do it.
Possibly the cables are too short. 8)
You'll get used to us on here. :D
ELZE
Post by ELZE » Fri Dec 20, 2013 8:35 pm
You're not alone...I posted two previous messages this week and when I looked they were not there also???
Post by Simon Jones » Fri Dec 20, 2013 10:36 pm
If the battery is past it's prime and been allowed to get heavily discharged, the plates can distort which short out the cells so not only will it not hold a full charge, it will drag the voltage down on anything else that is connected to it.
Hopefully by now, there will have been time to have charged it up by conventional means.
warriorsteve
Post by warriorsteve » Mon Dec 23, 2013 8:57 pm
Guys thanks for all your help.
In the end I have charged the battery as per normal, refitted it and away first time.
I can only presume my car didn't have enough 'ummph' to start the Bongo.
First lesson learnt! #-o
Post by Bob » Mon Dec 23, 2013 9:06 pm
Good result, thanks for updating us. :D
