battery monitor...anyone used this one?
Moderator: Ian
nicstrike
Post by nicstrike » Thu Dec 12, 2013 11:06 pm
on the back of my "split charge woes" post , I was thinking about hard wiring a pair of battery condition monitors but came across this http://www.ebay.co.uk/itm/300628609035? ... 1438.l2649 and wondered whether anyone has used one? I have a separate 12v socket wired directly off the vehicle battery , so when I re-connect the willinton kit I can test both batteries independently.
Re: battery monitor...anyone used this one?
Post by g8dhe » Fri Dec 13, 2013 10:50 am
If you have an existing voltmeter anywhere in the vehicle (Zig Marque 1 say) then it doesn't do anything different than that does.
winchman
Post by winchman » Fri Dec 13, 2013 12:23 pm
I fitted this about two years ago.
http://www.ebay.co.uk/itm/Blue-LCD-Volt ... 230ffe71fe
I have a BMW clock conversion and it fits with a bit of cutting in the back of the little cubby, I also have a switch on it as I find it distracting whilst driving so I can just turn it on and off when I want to look at whats going on.
We did a calibration check at work and it wat accurate to 0.002 of a volt so fine for our application
nicstrike
Post by nicstrike » Fri Dec 13, 2013 2:21 pm
I don't have any monitoring equipment in the bongo , hence my wish to fit something. I thought the portable unit was a good idea as I could use it in our other vehicles too. as I said I was initially thinking of one hard wired unit per battery but I suppose I could fit just one on a change over switch (on/off/on) instead? I had been looking at the gammatronix unit http://www.ebay.co.uk/itm/5mm-LED-12v-B ... 2eb6be3fd0 as it could be fitted unobtrusively.
winchman
Post by winchman » Fri Dec 13, 2013 2:36 pm
Looks good as long as you have a sheet of what each colour means, I like the compactness of it too
Gasy
Post by Gasy » Fri Dec 13, 2013 6:02 pm
I have a similar 3 light set up on a cigar lighter 2 way splitter
It's no good at all don't waste ya money
Get one or two like winch man has above
There not much of eBay
the1andonly
Post by the1andonly » Fri Dec 13, 2013 7:51 pm
I have a similar set up to winchman with a voltmeter in cubby but with a dual pole momentary switch that swaps from LB to SB when pressed up or down or off when left. Real numbers are easier to discuss than I've an orange led is the alternator ok? Simple voltmeters that fit in the cigar lighter also exist
http://www.ebay.co.uk/itm/Newest-Econom ... 540179aef2
Post by Simon Jones » Fri Dec 13, 2013 8:27 pm
I've used LCD meters and basic LED displays. I actually prefer the simplicity and readability of the LED type. You can see whats happening at a glance based on the colour or number of LEDs without having to read the fluctuating reading.
nicstrike
Post by nicstrike » Fri Dec 13, 2013 8:35 pm
blimey....just found one of those small plug in ones for £1.65 inc p&p....from hong kong!!! (every penny counts....just had a service and 2 punctures this week!) im thinking that could be cut and shut into a panel mounted job that would take up very little room , then either a on/off/on or a momentary switch for each battery.
winchman
Post by winchman » Fri Dec 13, 2013 9:12 pm
nicstrike wrote:blimey....just found one of those small plug in ones for £1.65 inc p&p....from hong kong!!! (every penny counts....just had a service and 2 punctures this week!) im thinking that could be cut and shut into a panel mounted job that would take up very little room , then either a on/off/on or a momentary switch for each battery.
Buy two you tight wad :D
Bet it would cost more for a switch
Post by g8dhe » Fri Dec 13, 2013 9:29 pm
It measures the voltage from the source, so you would have to bring another wire out to switch it to another battery, buy two and have one socket on each battery instead!
nicstrike
Post by nicstrike » Fri Dec 13, 2013 9:31 pm
tight wad?!! .... I represent that remark! :D you are right about the cost of a switch but I have just formulated a cunning plan. I have a spare window blind switch kicking (and wire) about in the garage somewhere..... mmm decisions decisions.
winchman
Post by winchman » Fri Dec 13, 2013 10:00 pm
You must have some junk kicking about you could make the lot meter and all
Here
http://going-green-battery.blogspot.co.uk/
Or here
http://paulorenato.com/joomla/index.php ... 7&Itemid=2
I am well known for my short arms and deep pockets :D
winchman
Post by winchman » Fri Dec 13, 2013 10:02 pm
Why don't you make one out of Cake?
It would be very handy as you could eat it if you got hungry.
nicstrike
Post by nicstrike » Fri Dec 13, 2013 10:07 pm
ahh you see.... the bi-latereal co-signal residual resistance value of hevva cake (that's lost those north of the tamar) peaks at 32.5 gigga crumbs , which means it is only suitable for 6v systems!
Return to “Pimp My Bongo”
