new Radiator for complete car idiot....
Hi All,
as per title really, finally found a decent garage to take a look at the coolant leak and they say it needs a new Rad, the suppliers they use quotes 280quid,
i am assuming that as long as its for a diesel its ok? or does it need to be for an auto too??? mines 2.5TD 2WD 1996 AUTO....
ive hunted around and i've seen ones on ebay for 80quid (!! to good to be true?), bongobits.com for 118quid, and mazdabongo.com for 115 and on here for 135quid (the bongo shop)
I could do with one posted up to the highlands almost straight away so if anyone knows/used these listed above then i'd be very appreciative!!!!!
thanks!
thanks!
Re: new Radiator for complete car idiot....
got an 80 quid ebay job in mine for 18 months or so
can you remember the user?
These seem to be ebay powersellers with good ratings.
http://www.ebay.co.uk/itm/MAZDA-BONGO-2 ... 4ac6a79943
looks same but i really dont recall user name
All the rads are similar quality build and that price is about right, just make sure your well versed in the bleeding process if your draining the system down
Nath
Nath
I am sure wheel quick in wigan will post you one
http://www.wheelquick.co.uk/
I've gone for the ebay one, it was an extra 10quid postage and will be at the garage in 2 days. i'll post back how i get on and if any issued.
thanks for the advice!!!!!
cheers
cheers
- mikeWalsall
If it's the same rad as in the video .. make sure the garage blank off the overflow pipe by the pressure cap ..
Would suggest you Give it a good flush/reverse flush to make sure you get any Metal fines out before fitting
V6 Mushroom
thanks for the suggestions, i'll pass it on to the garage.
delivery is already scheduled for tomorrow as the rad is t&t'd
so will let you know about quality / fitting soon
- haydn callow
Has the garage fitted a rad to a Bongo before and more importantly do they know how to bleed a Bongo? Get this wrong and you are looking at the cost of a new cylinder head.......look at the "bleeding Bongos" video on YouTube ..... Download the fact sheet and hand it to the garage..
Ignore at your peril !!
THANKYOU haydn - they have worked on Bongo's before, so they were a great find.
but to be SAFE i'll print!!!
the fact sheet seems to be GONE!
http://www.bongoforum.co.uk/enter/index ... &Itemid=79
- Simon Jones
That link is to the other forum. I believe their big 'thing' is that all their factsheets are available to access free of charge. Or, perhaps not
There is a factsheet on changing the radiator which might be useful: http://www.igmaynard.co.uk/bongo/member ... diator.pdf
The YouTube video is likely to make more sense anyway.
thanks everyone, i spoke to the garage, they use some kind of vacuum way of doing it to ensure no air....
- mikeWalsall
Yes that's what I use ..
As an 110% amateur .. I don't want to teach a professional 'granny' to suck eggs .. but it is still worth while 'wriggling' the pipes in case any 'stubborn' air is lodged in any nooks .. grannies and bends ..
