Clunking noise?
Nutcase
Clunking noise?
Post by Nutcase » Fri Dec 06, 2013 8:45 pm
Hi guys, just recently my freeda '2.5td'has developed a Clunking noise when going very slow ie' parking etc and it appears to be coming from of but only when on extreme lock either direction, has anyone got any ideas and if so is it a DIY job.
Cheers guys
the laird
Re: Clunking noise?
Post by the laird » Fri Dec 06, 2013 8:58 pm
Is it a fwd ?
Nutcase
Re: Clunking noise?
Post by Nutcase » Fri Dec 06, 2013 9:11 pm
Sorry forgot to say it is 4 wheel drive
Nutcase
Re: Clunking noise?
Post by Nutcase » Fri Dec 06, 2013 9:14 pm
Just read my first post and there is a bit missing?
It is coming from the osf but only when going very slow parking etc.
kentait
Re: Clunking noise?
Post by kentait » Fri Dec 06, 2013 9:17 pm
probably the c.v. joints. Not a d.i.y. job as the wheel alignment will have to be re-done.
regards, ken tait
Nutcase
Re: Clunking noise?
Post by Nutcase » Fri Dec 06, 2013 9:28 pm
Thanks Ken, will they have gone or just need stripping and regressing, oh and thanks.
the laird
Re: Clunking noise?
Post by the laird » Fri Dec 06, 2013 9:39 pm
In my experiance a replacement shaft would be the best fix ! If it is the cv joint
kentait
Re: Clunking noise?
Post by kentait » Sat Dec 07, 2013 11:48 am
stripping and re-greasing may help temporarily. gordon's (the laird) suggestion to replace the whole drive shaft is probably the easier job, but more expensive, unless you can source one from scrap. i may have been wrong regarding the wheel alignment,though, as th cv joints may not affect this.
briwy
Re: Clunking noise?
Post by briwy » Sat Dec 07, 2013 5:47 pm
It could well be the above but check the drop links and anti roll bar bushes first. If there knackered the noise can show up at strange times.
Much cheaper and easier than CVs.
