Glow plug light
elbee
Glow plug light
Post by elbee » Wed Nov 27, 2013 12:08 am
Lately when I start the bongo the glow light goes out then comes back on for about two seconds after the engine has started before going out again, never noticed it doing that before, is this normal? :?
Re: Glow plug light
Post by Northern Bongolow » Wed Nov 27, 2013 8:17 pm
no its not.
put a multi meter on the battery when you start the bongo.
battery at rest if its not too cold 12.5 volts.
turn key on to glow it may drop to 10-11 volts.
normal quick crank start--9 volts.
started running but glow plugs still on during short warm up---high 13 or 14 plus as the battery quickly recovers.
yours sounds like its struggling to UP the charge rate after starting, maybe a lazy batt or alternator on it way out but still just coping.
elbee
Re: Glow plug light
Post by elbee » Wed Nov 27, 2013 11:28 pm
Thanks northern bongo I'll get the multi meter out tomorrow, I hope the alternator is not on the way out :(
Peg leg Pete
Re: Glow plug light
Post by Peg leg Pete » Thu Nov 28, 2013 5:39 pm
Our Bongo is doing the same!!!
going back to dealer to be sorted soon!
Image Pete
elbee
Re: Glow plug light
Post by elbee » Thu Nov 28, 2013 9:24 pm
Let me know what it was Pete when they sort it :D
Re: Glow plug light
Post by Northern Bongolow » Thu Nov 28, 2013 9:46 pm
the glowplug light is a warning light for the charge system, the ecu spots the fault and triggers the light.
Peg leg Pete
Re: Glow plug light
Post by Peg leg Pete » Thu Nov 28, 2013 9:52 pm
I will do, bongo getting sorted in a weeks time :)
Image Pete
Diplomat
Re: Glow plug light
Post by Diplomat » Thu Nov 28, 2013 9:55 pm
I seem to remember, from a thread in the dim and distant past, a modification whereby you could switch off the automatic application of current to the glow plugs (to prolong their life) and also introducing the facility of having the light come on to indicate all glow plug activity after starting when you opt to switch the glow plugs into use.
This is something that has always been on my 'round tuit' list. Maybe some Bongos are doing this mod themselves?
Frank
They flew, I took up naturism
