wiring help
hammy67
wiring help
Post by hammy67 » Mon Nov 25, 2013 6:32 pm
starting to rebuild my engine which is a 1995 diesel, and I cant remember the wiring on the starter motor.where the cables for the starter motor come out there is the heavy cable with eyelet that goes to the started motor , there is a smaller wire with a spade connector that also goes to the starter motor , however coming out of the same loom as the other two wires is a third wire with a eyelet crimp on the end I am sure it is a earth but just want to make sure
Re: wiring help
Post by Northern Bongolow » Mon Nov 25, 2013 9:07 pm
is it a twin battery winter pack model with an engine switch on the dash, or a single starter battery and/or leisure battery.
hammy67
Re: wiring help
Post by hammy67 » Mon Nov 25, 2013 10:53 pm
Single battery just need someone to look at the loom nr starter motor please
Re: wiring help
Post by g8dhe » Tue Nov 26, 2013 11:24 am
I'm sure this was discussed - maybe on the other forum - recently ?? Or is this another case ?
