Another temp gauge query
stuc
Post by stuc » Sun Nov 10, 2013 6:23 pm
Hi got a fault with temp gauge today.
When pulling up to a stop in D with foot on brake, temp gauge drops off as if not working. Put it into P and handbrake on it goes back to normal running temp until you stop again. It sits at correct temp when running.
I suspect dodgy temp sensor or connection, where is it?
Has anyone had similar problem or any ideas?
Another thought, recently had gas conversion would they have linked in to the temp gauge for cut in point?
2.0L petrol 2wd auto.
Re: Another temp gauge query
Post by Northern Bongolow » Sun Nov 10, 2013 6:50 pm
lancyman
Post by lancyman » Sun Nov 10, 2013 7:42 pm
As I have now found out it's the single green wire by
The egr pipe at the front right of the engine block,
Under drivers seat. Took mine off for a clean today.
Post by Northern Bongolow » Sun Nov 10, 2013 7:46 pm
stuc has the 2ltr so may be different. :wink:------------------------------ from a proper bongo like ours.
Post by Simon Jones » Sun Nov 10, 2013 8:38 pm
stuc wrote:Another thought, recently had gas conversion would they have linked in to the temp gauge for cut in point?
If it's anything like mine, the temp sensor is built into the evaporator so it measures the coolant temp at the point it heats the LPG.
stuc
Post by stuc » Sun Nov 10, 2013 9:39 pm
Northern Bongolow wrote:stuc has the 2ltr so may be different. :wink:------------------------------ from a proper bongo like ours.
Proper Bongo? Are they the ones that won't let you sleep at night in case the overheat when they are parked up with no one even driving them? lol :shock: :lol:
stuc
Post by stuc » Sun Nov 10, 2013 9:42 pm
What system have you got? mines BRC. I know mine is linked in with the cooling system but not sure why.
Post by Northern Bongolow » Sun Nov 10, 2013 9:43 pm
it has been known :lol: :lol: :lol:
stuc
Post by stuc » Sun Nov 10, 2013 9:44 pm
lancyman wrote:As I have now found out it's the single green wire by
Was yours doing the same?
Post by Northern Bongolow » Sun Nov 10, 2013 9:47 pm
stuc check your alternator output on tick over, then revving, maybe a voltage issue.
stuc
Post by stuc » Sun Nov 10, 2013 9:55 pm
Cheers Ady will look tomorrow, but had an alternator on not too long ago so hope its not that, it would be covered by guarantee though. Have you heard of temp sensors working intermittently?
Post by Simon Jones » Sun Nov 10, 2013 10:02 pm
Mine's also a BRC and switches over at about 40 degrees C which is normally a couple of minutes from cold. The reason why it's plumbed into the cooling system is that the fuel needs to be heated to vaporise it.
Post by Northern Bongolow » Sun Nov 10, 2013 10:16 pm
stuc wrote:Cheers Ady will look tomorrow, but had an alternator on not too long ago so hope its not that, it would be covered by guarantee though. Have you heard of temp sensors working intermittently?
they work by splitting the voltage so any drop in voltage is soon noticed on the system.one reason is dirty or faulty sensor/wire, which yours maybe, or voltage dropping as revs drop, i have heard of the 2 ltr gauge being prone to being dodgy, maybe its mounted in a bad place.
stuc
Post by stuc » Sun Nov 10, 2013 10:38 pm
Cheers again, will keep you posted once I've had a look.
stuc
Post by stuc » Sun Nov 24, 2013 11:21 pm
Just an update, never got chance to have a look but problem has never happened again since. Thats the kind of problems I like. :D
