What wire ampage
Moderator: Ian
haybal
What wire ampage
Post by haybal » Tue Nov 05, 2013 11:33 am
Hi all,
I am looking to add some led's to the side step,have read some of the the threads which are really helpfull.
My question is what grade wire should i use for the +ve?, looking to tap into the interior light.
Barry
wonkanoby
Re: What wire ampage
Post by wonkanoby » Tue Nov 05, 2013 1:06 pm
almost any you have
they draw very little juice
Post by g8dhe » Tue Nov 05, 2013 3:14 pm
Use the same gauge as the existing wiring as the fuse, 10 Amp, is rated for the cable, if you use anything smaller then it might not be adequately protected by the 10 Amp fuse.
haybal
Post by haybal » Tue Nov 05, 2013 6:54 pm
g8dhe wrote:Use the same gauge as the existing wiring as the fuse, 10 Amp, is rated for the cable, if you use anything smaller then it might not be adequately protected by the 10 Amp fuse.
Not sure of the existing gauge, but if i was to use 15 amp wire would this be ok? then the 10 amp fuse would be the weak point protecting the cable. (If i have understood you right)
winchman
Post by winchman » Tue Nov 05, 2013 7:05 pm
Thats correct
The fuse should allways be the weakest link, if you fit a smaller cable say 5amp rated, then you had a dead short the cable would become the weakest link and could melt first and as its not designed to melt would possibly catch fire.
If you use a smaller cable just fit an inline fuse ( lower ampage to suit the cable) when you attach it to the bigger cable then if you do get a short this lower rated fuse will protect the cable.
Post by g8dhe » Tue Nov 05, 2013 8:31 pm
Yup, Thin walled insulation would be 32/0.20mm, 1mm2, 16.5amp. For standard wall insulation then something with 1.5mm2 cross-section would be fine.
hijimhere
Post by hijimhere » Tue Nov 05, 2013 9:07 pm
I assume your LED device will have a minimum current draw. I would be thinking of in line protection of say 2 x the current draw. Restricting the fuse rating is the best in line way of ensuring any risk is minimised.
haybal
Post by haybal » Tue Nov 05, 2013 9:51 pm
Thankyou all for your replies and knowledge =D> ,last thing i want is a fire in my pride and joy [-X .
Return to “Pimp My Bongo”
