back wiper woes
hwyaden
back wiper woes
Post by hwyaden » Mon Nov 04, 2013 11:52 am
i've changed the back wiper but it won't go anywhere near the window. i don't want to bend the wiper arm unless i have to as i might be missing something glaringly obvious OR have the wrong kind of wiper on it. does it need a specialist wiper? i've just got a new 16 " one and stuck on but it's not doing any good floating in mid air #-o
windywatson
Re: back wiper woes
Post by windywatson » Mon Nov 04, 2013 1:48 pm
Hi, the wiper is pulled onto the window by the spring under the wiper arm. It is possible that when you've pulled the RM way from the window that the spring has failed in some way. Might have stretched and lost its strength. Or if old and rusty may have just past the end of its life.
Its not uncommon for the spring to loose some strength an the wipers not clear the screen very well, but if its not even touching I would look closely at the spring and it is also possible that the hinge is tight.
I've personally replaced my rear wipers spring with a new one that has more strength and fitted one of the. New style single piece blade and it wipes well.
Windy-Watson
2001 V6 Tin Top
hwyaden
Re: back wiper woes
Post by hwyaden » Mon Nov 04, 2013 2:41 pm
oooh thanks - off to look at my spring now :D
ELZE
Re: back wiper woes
Post by ELZE » Mon Nov 04, 2013 3:42 pm
windywatson wrote:Hi, the wiper is pulled onto the window by the spring under the wiper arm. It is possible that when you've pulled the RM way from the window that the spring has failed in some way. Might have stretched and lost its strength. Or if old and rusty may have just past the end of its life.
I concur..this happened to me after fitting a new blade. Only noticed during a rain shower where the front was crystal clear and the ack looked like it had no wiper :roll: :roll: Sprayed everything with WD pulled and shoved a bit and result!
ELZE
Re: back wiper woes
Post by ELZE » Mon Nov 04, 2013 3:54 pm
Not wanting to hijack the thread but as its rear wipers I hope you wont mind. Mine has a stub where the wiper was. I seems to have the controls on the stalk so was wondering if it could be reinstated? I will post a picture v. soon so you know what I mean. Maybe they were fitted as standard but for some reason our Japanes owner / friend has bastardised this one?
Picture pending and thanks
ELZE
Re: back wiper woes
Post by ELZE » Mon Nov 04, 2013 4:27 pm
Well this one is with the cap fitted
I was posting the other picture with the cap removed then photbucket went into a dive and logged me out?
So is reinstatement possible ot just a waste of time and energy? I would not even be discussing this if it were not for my rear R sole camera getting obstructed in heavy weather
mikeWalsall
Re: back wiper woes
Post by mikeWalsall » Mon Nov 04, 2013 4:57 pm
I thought all Bongos had a rear wash / wipe as standard ..
Does the wash work .. and the spindle rotate when you move the steering wheel switch ..??
ELZE
Re: back wiper woes
Post by ELZE » Mon Nov 04, 2013 6:22 pm
mikeWalsall wrote:I thought all Bongos had a rear wash / wipe as standard ..
That's what I think and so I am asking what the chances are that mine has too and its been interered with for some reason. Maybe it does not rain in Japan :lol: :lol: The spindle does not turn and the washer does not actuvate when pushed?? The stalk has the facility to (turn when twisted for washers) the twisted the other way for wiper but nowt happens
I am thinking replace the fuse (which one) in the box, checkout the washers for missing parts, renew the wiper and give it a go. However lot of time and money wasted if it turns out to be a bummer. Has anyone else come across this previoulsy
Re: back wiper woes
Post by g8dhe » Mon Nov 04, 2013 8:35 pm
There have been previous threads where rear wipers have been removed due to problems with the support/bearing. The problem is if its fitted but NOT working then its an MOT failure, if its not present then it can't be tested and thus can't be failed .... idiotic to my mind but there we go .... :roll:
hwyaden
Re: back wiper woes
Post by hwyaden » Mon Nov 04, 2013 9:28 pm
how weird! :-k
Gasy
Re: back wiper woes
Post by Gasy » Tue Nov 05, 2013 9:17 am
Rear wash / wipe fuse is number 13 next to drivers right knee
Re: back wiper woes
Post by rita » Tue Nov 05, 2013 12:11 pm
Hi Mike, they are (were)in fact fitted to these vehicles as an Optional Extra.(just a bit of useless information) :)
mikeWalsall
Re: back wiper woes
Post by mikeWalsall » Tue Nov 05, 2013 12:50 pm
Thanks .. I wrongly assumed .. can't say that I have ever looked to take notice on other Bongos ..!!
I was a bit bemused to find that the rear wiper on mine does not have an intermittent wipe feature ..
There again, I find by pushing the wiper stalk to the dash .. the one swipe feature useful for the front screen..
cmm303
Re: back wiper woes
Post by cmm303 » Tue Nov 05, 2013 2:24 pm
mikeWalsall wrote:.... I was a bit bemused to find that the rear wiper on mine does not have an intermittent wipe feature .. ..
+1, pain on wet roads.
mikeWalsall wrote:There again, I find by pushing the wiper stalk to the dash .. the one swipe feature useful for the front screen..
#-o :shock: Learnt something, cant wait to give it a go!
Chris with BertieB
hwyaden
Re: back wiper woes
Post by hwyaden » Tue Nov 05, 2013 3:17 pm
i've had a good look at my wiper and come to the conclusion that someone has buggered it up by painting it black. the front wipers were the same but my son blitzed them with wd40 and it seemed to cure the problem. no such luck on the back, the spring is solid as a rock.
where can i get a replacement spring, or failing that a new arm? i've tried searching the usual places but nothing comes up :?
