help needed heater blower
lily
Post by lily » Wed Oct 30, 2013 11:37 pm
hi still having problems with heater blower have had new resister fitted but went off after 2 days now the garage have fitted a temperiary switch for me that I switch on to make fan work to demist front windows in mornings.the heater has always heated up but the dial 1 to 4 did not work they fitted the bypass switch because they could not find the earth to the fan does any body know were this is located so I can have it repaired properly please :D :D :D
wonkanoby
Re: help needed heater blower
Post by wonkanoby » Thu Oct 31, 2013 9:10 am
there are 2 wires coming of the fan .....one is the earth
have you stripped fan down and cleaned it...and looked at state of brushes
Post by Northern Bongolow » Thu Oct 31, 2013 8:55 pm
if you put a live to one wire on the motor feed and earth the other the fan works, but this may not be how the system is wired. it MAY be that the resister is switching the earth as well as the live, or that the blow selector completes the earth.
this MAY mean that the 2 wires at the motor are both live.
maybe Geoff can confirm how the system is wired. [-o<
Post by g8dhe » Thu Oct 31, 2013 9:49 pm
It sounds like the older mechanical system, both methods apply (just to complicate the issue!);
The +12 volts is switched to the fan motor by a relay, when the ignition is turned on.
The speed is controlled by the resistors on the low or earthy side of the motor.
With the first switch position being Off where no resistor is connected.
The relay is G1-03
The resistors are G1-05
and the switch is G1-06
The electronic "Climate Control" version is different however ...
Post by Northern Bongolow » Sat Nov 02, 2013 12:10 am
cheers Geoff. #-o :wink:
