Short in the lights??
Dr Fingers
Post by Dr Fingers » Sat Oct 26, 2013 5:22 pm
Full beam indicator is on when lights are in dipped position, accompanied by a distinctly 'burning electrical' smell :shock:
I'm no auto electrician, but can anybody point me in a general direction to trace this problem?
Much appreciated.
Derek
the laird
Re: Short in the lights??
Post by the laird » Sat Oct 26, 2013 5:41 pm
If you think the smell is coming from around the steering wheel area it's probably the indicator dip/main beam switch is u/s
winchman
Post by winchman » Sat Oct 26, 2013 6:46 pm
First job is check the earths, had this recently on a Micra, it was the switch and a poor earth behind the head light
Dr Fingers
Post by Dr Fingers » Sat Oct 26, 2013 7:00 pm
the laird wrote:If you think the smell is coming from around the steering wheel area it's probably the indicator dip/main beam switch is u/s
Worth a spray with switch cleaner?
winchman
Post by winchman » Sat Oct 26, 2013 7:39 pm
Check the Earths first.
The ones I have done on other cars have all mechanically failed and fell to pieces internally.
It could possibly be a stuck relay too.
Post by Northern Bongolow » Sat Oct 26, 2013 9:24 pm
check/remove the plugs on the headlight bulbs, one or both will maybe have melted.
Dr Fingers
Post by Dr Fingers » Sun Oct 27, 2013 12:52 pm
Turns out it's a dodgy earth to the n/s headlight.
Thanks folks..
Derek
mikeWalsall
Post by mikeWalsall » Sun Oct 27, 2013 2:56 pm
Burnt wires / bulb connections are a common problem and new connections are easily sourced ..
http://www.ebay.co.uk/itm/H4-Headlamp-H ... 20d8efd1ef
Dr Fingers
Post by Dr Fingers » Sun Oct 27, 2013 3:31 pm
mikeWalsall wrote:Burnt wires / bulb connections are a common problem and new connections are easily sourced ..
Thanks so much for this link, that's exactly what I need. This is exactly why this Forum is pure gold dust :D
Derek
winchman
Post by winchman » Sun Oct 27, 2013 6:25 pm
Glad we could help
I would repair any iffy earths and fit an additional one on each headlight should last for ever then.
