ecu replacement
alan
ecu replacement
Post by alan » Sat Oct 26, 2013 7:58 am
Hello all we are try to get the Bongo back on the road after she been ill for so long wew pin her trouble down to the ecu #-o yeh had to be the cheap part not #-o
Any way she need so she going to be fixed i got the part number of my bongo so found a 2snd hand one from one near the same age as ours but part number do not match up now i know some time there dont macth up for patent parts ect .
i should add that mine a v reg (2000) 4x4 td there is y reg both fly by wire
The part number on my bongo .
WLB2
WLB2 18881C
E6T05271H 9Z15
There part number
WLB2
WLB2 1881D
E6TO5171H1 0619
so think well there part work in mine as if dose it means she be back on the road with in the week.
So the question is well it work?
take it easy drive a bongo
Re: ecu replacement
Post by mikeonb4c » Sat Oct 26, 2013 8:36 am
Fingers crossed for you Alan [-o<
alan
Re: ecu replacement
Post by alan » Sat Oct 26, 2013 8:52 am
Thanks MIke if the ones in the know say it well then i be sroted if not then it a new one and over 4 weeks tells she be back #-o
Re: ecu replacement
Post by Simon Jones » Sat Oct 26, 2013 9:19 am
Bellhill Garage have a lot of ECUs for sale: http://stores.ebay.co.uk/BELL-HILL-GARA ... d=60678461
If you can get your van to them, I'm sure they'd be happy to let you try it first.
alan
Re: ecu replacement
Post by alan » Sat Oct 26, 2013 9:24 am
Simon Jones wrote:Bellhill Garage have a lot of ECUs for sale: http://stores.ebay.co.uk/BELL-HILL-GARA ... d=60678461
thank simon i tryed them too none that macth up wishing i had a older van some of the time and she in bits now too so cant driver her #-o
alan
Re: ecu replacement
Post by alan » Wed Dec 18, 2013 11:35 pm
#-o #-o #-o #-o new ecu fitted and the fault just came bk on grrrrrrrrrrrrrrrr starting to heat bongo
think about scrap it and move on never thought I would say those words but need to get some transport sorted
Re: ecu replacement
Post by Bob » Wed Dec 18, 2013 11:38 pm
Oh No. :(
Re: ecu replacement
Post by Simon Jones » Wed Dec 18, 2013 11:51 pm
I read on here recently that the overwhelming majority of ECU 'faults' are traced to sensors giving erroneous readings. Remind us again, what are the symptoms and fault codes you are getting?
alan
Re: ecu replacement
Post by alan » Fri Dec 20, 2013 11:39 pm
http://igmaynard.co.uk/bongo/forum/view ... =3&t=62368
tink this was the 1st post about van playing up
#-o
Re: ecu replacement
Post by Simon Jones » Sat Dec 21, 2013 12:14 am
alan
Re: ecu replacement
Post by alan » Sun Jan 12, 2014 9:35 pm
#-o #-o finding my self looking at the drack side ( vw)
GreenBongo
Re: ecu replacement
Post by GreenBongo » Sun Jan 12, 2014 11:16 pm
Most EGR faults are due to clogged passageways. When you clear the codes does the fault come back at key on or when driving? under what conditions?
alan
Re: ecu replacement
Post by alan » Mon Jan 13, 2014 8:32 am
[quote="GreenBongo"]Most EGR faults are due to clogged passageways. When you clear the codes does the fault come back at key on or when driving? under what conditions.
finger crossed think we might be there now [-o<
but to answers your question it comes on when driving but not under the same conditions which is why it taking the beep to try to sort #-o #-o #-o
GreenBongo
Re: ecu replacement
Post by GreenBongo » Mon Jan 13, 2014 9:34 am
Usually the ECU does an electrical check on key on so the circuit should be good. If its coming on 'at random' then it could be a sticky EGR valve, the ECU usually tests the passageways by flicking the EGR open during deceleration and then looking for a change in manifold pressure.
Re: ecu replacement
Post by Simon Jones » Mon Jan 13, 2014 2:24 pm
A lot of folk blank or disconnect the EGR valve with no issues, although that is generally on the pre-drive by wire versions.
