having a nightmere
lily
having a nightmere
Post by lily » Sat Oct 19, 2013 11:49 pm
after having a new resister fitted that at first did not work but garage sorted it at the second attempt every thing was working fine for a day or two know everything is off air con,rear heater,and fan speed I suspect it may of blown a fuse that has caused all these to stop at once please can any one advise as difficult to see when driving in wet weather as I cannot demist windscreen thanks lily
Re: having a nightmere
Post by g8dhe » Sun Oct 20, 2013 10:38 am
The first suspect will be this fuse;
That will also control the rear demister. There are other possibilities but start with that one, shout if it isn't the fault.
