Headlights
David Edwards
Headlights
Post by David Edwards » Fri Oct 18, 2013 12:10 pm
Going through the advisor on my new mot and they have put, "Both front headlamps deteriorated but light output not reduced", now both have been polished up and the film removed and they both look fine to me, I will change the bulbs as a matter of course, when asked they just said light was not good, now has anyone else come across this, does it mean the actual headlamp itself is knackered or what, I am still a bit confused,lol.
Re: Headlights
Post by Muzorewa » Fri Oct 18, 2013 12:12 pm
I don't get it, if the light output isn't reduced, what's the problem? :?
David Edwards
Re: Headlights
Post by David Edwards » Fri Oct 18, 2013 12:14 pm
Yep I know cant work it out I have the 50% BRIGHTER H4 bulbs in there so should be ok. Are there led ones available that would be brighter but without the heat generated.
Re: Headlights
Post by Simon Jones » Fri Oct 18, 2013 12:43 pm
Are they referring to main beam or dipped beam?
Last time I read up on it, there were no LED lamps approved for use as main / dipped beam. Even if there was, it is unlikely they would be available to retrofit to an existing lamp unit. I used to find the Lidl/Aldi bulbs made by Osram were the best in terms of light output & price.
Darkstar
Re: Headlights
Post by Darkstar » Fri Oct 18, 2013 1:03 pm
Does he mean the reflector at the back of the light unit?
Got a Bongo for the Wife, Best trade-in ever
David Edwards
Re: Headlights
Post by David Edwards » Fri Oct 18, 2013 5:00 pm
Not sure but I have checked it and it looks fine, the garage who fitted my engine did this lot of work for me so I asked them, they said the lights are fine and they dont know what they are on about really either.
Re: Headlights
Post by teenmal » Fri Oct 18, 2013 7:12 pm
Its probably the reflector that is beginning to lose its shine. It would show up on the beam tester.
