Break down
Whiskyman
Break down
Post by Whiskyman » Thu Oct 17, 2013 5:53 pm
not a mechanically minded sort of person but i do like my BONGO (FREIDA) .
when i try to start it all i am getting is a rapid clicking noise from under the bonnet drivers side
Gasy
Re: Break down
Post by Gasy » Thu Oct 17, 2013 6:02 pm
Starter motor
Or starter motor solenoid
Or flattish battery
I would think
What engine gear box do you have
Whiskyman
Re: Break down
Post by Whiskyman » Thu Oct 17, 2013 6:07 pm
Automatic 2 1/2 L
Gasy
Re: Break down
Post by Gasy » Thu Oct 17, 2013 6:11 pm
You carnt bump start it then
You can get repair kits for the starter motor
Is your battery charged does it read more than 12 volts when tested
Gasy
Re: Break down
Post by Gasy » Thu Oct 17, 2013 6:14 pm
Tap / hit your starter motor a few times then try it
Re: Break down
Post by Bob » Thu Oct 17, 2013 7:04 pm
If you're in North Somerset/Bristol I'll come and have a look.
ELZE
Re: Break down
Post by ELZE » Thu Oct 17, 2013 7:17 pm
Make sure the battery is fully charged first
Jammed starter motor is a possibility or maybe a lazy starter. The cold weather is starting to take hold and this is when the weaknesses come to light! I have just charged up my spare battery just in case!
helen&tony
Re: Break down
Post by helen&tony » Fri Oct 18, 2013 3:30 am
First things first. As stated, it may be the battery, so, disconnect it, check the voltage, and THOROUGHLY clean the battery terminals and the clamps. They must be bright and clean. If the battery has a good charge, smear a bit of vaseline around each terminal, and replace the clamps TIGHT....sometimes a loose or dirty terminal will prevent a battery connecting properly. Also, clean the top of the battery, as accumulated dirt can conduct.
Next step is to check the earth connections to the body, at the battery earth strap, and the starter. Clean them up.
If the battery has a good charge , and the terminals are clean, then try again. If no luck, then, as previously stated, try the solenoid and starter motor.
