resister
lily
resister
Post by lily » Wed Oct 16, 2013 10:48 pm
Purchased a new resister from bongo shop 65pound fitted it but the control for the heaters still does not work. The heater works but i cannot demist the windows i have checked the fan and it works what else. Can it be totaly stumped can any one give advise please. And what fuse is it and where is it locates thanks
Re: resister
Post by Bob » Wed Oct 16, 2013 11:09 pm
Possibly the linkage (down by your left foot) which controls where the heater actualy blows the air has come apart.
Does the knob which sends air to feet/demist/face vents feel loose?
This is a simple DIY fix, so fingers crossed.
Re: resister
Post by Simon Jones » Wed Oct 16, 2013 11:49 pm
If the fan was working on all speeds beforehand, then you didn't need to buy new resistor. They only tend to fail when the motor bearing start to seize up. Is your aircon working correctly? If its not, then the windscreen demist function will not be so effective.
hijimhere
Re: resister
Post by hijimhere » Thu Oct 17, 2013 12:53 am
misting up can occur in these temperatures if you have the heater setting to recirculate - when misting begins reset to take air in!
Re: resister
Post by g8dhe » Thu Oct 17, 2013 10:20 am
To use the Demister requires that the air has the moisture removed from it, this requires that the Air Con system is actually working i.e. is cooling down the incoming air so that the moisture condenses out. If the Air Con system itself is not working then you won't be able to demist. Has the Air Con been refilled recently ? Can you get the air temperature down to very low temperatures normally ? If not then get the Air Con system overhauled you may find that there is no cooling going on at all!
Please note the Air Con and the blowers/heaters are NOT the same thing....
mikeWalsall
Re: resister
Post by mikeWalsall » Thu Oct 17, 2013 12:36 pm
You can still demist the screen with just hot air .. but without a working air conditioning you cannot extract the moister from the air ..
On the digital system the fully working system is very efficient ... simply by pressing the middle left demist button that automatically .. puts the heater blower fans on .. directs the pre set temperature air to the screen and turns the AC on to de humidify (dry out) the interior ..
Different people have different preferences .. personally, I think it is better to initially dry out the air already in the vehicle .. rather than trying to dry out incoming moist air as well as what's already in the interior .. so I press the top left button in and recycle the interior air ..
lily
Re: resister
Post by lily » Thu Oct 17, 2013 4:57 pm
Thanks for all your replys it was the pins on the new resister they needed ajusted slightly every thing fine for know did thi nk i had bought resister that i didnot need dont know if the old one works are not but if anyone would like they can have maybe if its broke they could repair it just send a message i will pop it in post once again thanks for your replys :D :D
Re: resister
Post by teenmal » Sun Oct 20, 2013 8:00 pm
lily wrote:Purchased a new resister from bongo shop 65pound fitted it but the control for the heaters still does not work. The heater works but i cannot demist the windows i have checked the fan and it works what else. Can it be totaly stumped can any one give advise please. And what fuse is it and where is it locates thanks
Is this a misprint :shock:
Re: resister
Post by Simon Jones » Sun Oct 20, 2013 9:17 pm
No: http://www.igmaynard.co.uk/bongo/mercha ... #Electrics
Keeping the drain pipe on the scuttle panel clear will prevent water ingress to the motor which is usually the start of the problems, so it's easy to save yourself £65 (or £116 in the case of digital climate control).
