Headlights not working
iangrimmer
Post by iangrimmer » Mon Oct 14, 2013 6:37 pm
The headlights aren't working on my 1999 2.0 petrol Bongo. When I switch on the headlights there is nothing happening on normal or main beam. Yet the headlight 'flasher' works fine as do all the other lights. Checked fuses, bulbs and all okay there.
Any ideas anyone?
Re: Headlights not working
Post by g8dhe » Mon Oct 14, 2013 8:36 pm
Welcome to the forum!
Most likely your Head light relay is not working (The Flash switch operates direct to the bulb);
The relay is E1-04;
Which is the rear most of a possible 4 (not all may be fitted) on the nearside wing under the bonnet.
