Sink drain
mellon man
Sink drain
Post by mellon man » Sun Oct 06, 2013 8:30 am
I NEED TO KNOW PLEASE- can I use the gridded hole mid way in the floor of my Bongo for a outlet drain for my sink waste ?
Re: Sink drain
Post by Simon Jones » Sun Oct 06, 2013 9:41 am
Gridded hole? If that's a vent fitted by a convertor, then it's intended to allow any gas leak to escape safely so you wouldn't want to partially block it up.
mellon man
Re: Sink drain
Post by mellon man » Sun Oct 06, 2013 10:03 am
Oh so it's not a standard hole then - it's a gas breather/escape vent for gas cooker is it ?
Thanks for info Simon as pervious owners had it covered with a large rear mat will now cut out section of mat so it can do it's job =D>
And I will have to revert back to my 5 litre (x comfort conditioner bottle) plastic container for the collection of waste grey water
Re: Sink drain
Post by g8dhe » Sun Oct 06, 2013 11:37 am
Normally the gas vent hole is in the same area as the gas bottle, is that where the gas bottle is stored?
mellon man
Re: Sink drain
Post by mellon man » Sun Oct 06, 2013 12:12 pm
The sink/cooker unit is along the left side ((where the rear heater controls are) a small Gas bottle sits in a tin metal box in the cupboard under a metal lined shelf that is under the cooker hob, the unit is open backed so I guess fumes should go out the back and down to the vent that is in the floor more central.
