leisure batteries
Moderator: Muzorewa
stpn666
leisure batteries
Post by stpn666 » Sat Oct 05, 2013 5:25 pm
Hi All
New to all this bongo stuff so another silly question how do I run stuff from my leisure battery and can someone explain the hookup system to me please.
Steve
mikeWalsall
Re: leisure batteries
Post by mikeWalsall » Sat Oct 05, 2013 7:23 pm
It depends on what system you have .. and how the 'cab' is wired into it ..
Simple ones have a split charger when the engine is running it gives the stater battery priority charging ... then automatically switches over to charge the leisure battery ..
A simple fused harness feeds the relevant cabs fuse box terminals for (say) the power points (ciggy lighters) .. lecky blinds .. interior lights .. radio .. fridge .. TV or what ever ..
With this system if you camp on ( say) a green field site .. you use the lecky from the leisure battery ..
So you will still be able to start the Bongo from the dedicated starter battery ..
Post by g8dhe » Sat Oct 05, 2013 10:03 pm
The Electrical Hook Ups (EHU) are where you can plug into a pillar at the site to supply the van with 240V AC mains. Normally you have plug mounted under a flap on the van, which you run flexible cable to the site EHU pillar. Within the van the plug feeds a small Consumer Unit (switch and fuse box) that has a Master switch, and RCD (for safety) and then a number of feeds to main sockets or equipment, often you will have a couple of 13 Amp sockets mounted somewhere to plug in kettles/charges in etc. You may also have a 12 volt supply which connects into the 12 volt L/B system to charge the L/B (in addition to a Split charge system from the alternator) and run the 12 volt items from the EHU when you on site. This means you really only use the L/B when your parked up in an lay by or wild-camping.
stpn666
Post by stpn666 » Mon Oct 07, 2013 3:49 pm
Thank you for the info and replies I am grateful
Steve
windywatson
Post by windywatson » Mon Oct 07, 2013 6:36 pm
Hi Steve,
Welcome to the club. It's a good idea to add your location to your avitar or posts so that member's know where you are. That way you may get offers of help that include being able to meet and help with Bongo related issues.
Windy-Watson
2001 V6 Tin Top
