Vibrations
TimC
Vibrations
Post by TimC » Fri Sep 27, 2013 8:58 pm
Evening all
The bongo (diesel auto) has developed a bit of a vibration at idle and low speeds.
The FAQ talks about it potentially being the crank pulley, but I'm wondering if knackered engine mount(s) could give the same symptom?
Untraceable loose trim in the back rattles horrendously at certain resonance as well! Does my head in!
Tim
Re: Vibrations
Post by Northern Bongolow » Fri Sep 27, 2013 9:06 pm
usually prop shaft or centre prop bearing. is it 2 wheel d or 4 wheel drive.
the crank pulley usually makes a rattling sound. lift the passy seat, does it make a noise when stood still,
or vibrate when the bongo is moving (prop etc).
TimC
Re: Vibrations
Post by TimC » Fri Sep 27, 2013 9:13 pm
Northern Bongolow wrote:usually prop shaft or centre prop bearing. is it 2 wheel d or 4 wheel drive.
2 wheel drive and will vibrate in N with handbrake on. Worse in D at Idle.
Re: Vibrations
Post by Northern Bongolow » Fri Sep 27, 2013 11:36 pm
is this just after starting or when warmed up.
what revs is the rev counter showing when vibrating.
TimC
Re: Vibrations
Post by TimC » Fri Sep 27, 2013 11:46 pm
Northern Bongolow wrote:is this just after starting or when warmed up.
All the time, and just under 1k
Getcarter
Re: Vibrations
Post by Getcarter » Sat Sep 28, 2013 6:47 am
Sorry to hijack. My 2wd V6 has an odd shake when warm at idle, Rev counter showing 600-800. Very irregular. Do you think think that could be the propshaft or prop bearing?
V6 Tintop with LPG
Re: Vibrations
Post by Simon Jones » Sat Sep 28, 2013 8:49 am
Is the vehicle stationary at the time? If so, you can rule out prop shaft etc. more likely to be ignition problem. Check the HT leads carefully, especially at the bottom where the rubber shroud goes over the top of the plug. You're looking for oil, water or signs that the rubber is breaking down.
Re: Vibrations
Post by rita » Sat Sep 28, 2013 10:01 am
Simon Jones wrote:Is the vehicle stationary at the time? If so, you can rule out prop shaft etc. more likely to be ignition problem. Check the HT leads carefully, especially at the bottom where the rubber shroud goes over the top of the plug. You're looking for oil, water or signs that the rubber is breaking down.
Quote.....
Evening all
Try again :lol:
Re: Vibrations
Post by Simon Jones » Sat Sep 28, 2013 12:08 pm
Touché. 'tis you that should have gone to Specsavers :)
Getcarter wrote: Sorry to hijack. My 2wd V6 has an odd shake when warm at idle, Rev counter showing 600-800. Very irregular. Do you think think that could be the propshaft or prop bearing?
Re: Vibrations
Post by Northern Bongolow » Sat Sep 28, 2013 3:34 pm
what is the idle speed. both in neutral and in drive.
Getcarter
Re: Vibrations
Post by Getcarter » Sat Sep 28, 2013 7:38 pm
Thanks Simon. Yes, it is when stationary but it can be a bit jerky when accelerating. Could this also be down to bad HT leads?
V6 Tintop with LPG
Re: Vibrations
Post by Simon Jones » Sat Sep 28, 2013 9:13 pm
Yes, HT leads can start to break down a bit when they get old. If one of the rocker cover gaskets starts to leak, you also get oil in the spark plug wells which does not help. Personally, I'd remove, check and clean each lead in turn. You may not be able to see anything obvious, but what you could try is running the engine in the dark an looking for any signs of any 'tracking'. It wont hurt to check and clean the plugs too as you can learn a lot about the state of the engine by the colour and condition of them.
Getcarter
Re: Vibrations
Post by Getcarter » Sat Sep 28, 2013 9:36 pm
Thanks Simon and sorry TimC for hijacking your thread... :oops:
I hope you get sorted soon
V6 Tintop with LPG
TimC
Re: Vibrations
Post by TimC » Mon Sep 30, 2013 5:18 pm
Not entirely sure - lowish though. Very slight rev cures the worst of it
wonkanoby
Re: Vibrations
Post by wonkanoby » Mon Sep 30, 2013 8:43 pm
should tickover 700 to 780 rpm once warm
