Why won't the key turn in the ignition?
Bongoplotter
Post by Bongoplotter » Wed Sep 25, 2013 7:59 pm
Tried both keys in the ignition today, and neither of them will turn before a few attempts. Any ideas folks? Thanks.
Mat & Kat
Re: Why won't the key turn in the ignition?
Post by Mat & Kat » Wed Sep 25, 2013 8:13 pm
Only just got mine but the steering lock did seem to need quite some jiggling before it let me turn the key the other day.
Darkstar
Post by Darkstar » Wed Sep 25, 2013 8:13 pm
steering lock ?, try turning your steering wheel both ways whilst gently trying to turn ignition switch, its quite stiff with engine off.
Are they new keys?, may need a light rub over with emery to take the edge of them.
Sorry cant be of more help.
Got a Bongo for the Wife, Best trade-in ever
Bongoplotter
Post by Bongoplotter » Wed Sep 25, 2013 8:39 pm
Thanks, both keys are a few years old, and I can't even jiggle the steering wheel to take the steering lock off.
hijimhere
Post by hijimhere » Wed Sep 25, 2013 9:25 pm
Try to leave the steering in the straight ahead position. Could be the barrel in the ignition lock may be wearing out?? If your keys have a number maybe ask Tom to cut you a new one - search lock barrels for the thread with info
Post by Bob » Wed Sep 25, 2013 9:31 pm
Try pushing the brake pedal, then press the big button on the gear selector and jiggle shifter gently back and forth. [-o<
stuc
Post by stuc » Thu Sep 26, 2013 9:54 am
Bongoplotter wrote:Thanks, both keys are a few years old, and I can't even jiggle the steering wheel to take the steering lock off.
If the steering wheel won't move definitely sounds like steering lock. Use a bit of strength to turn the wheel to release the pressure off the lock. Had this problem with loads of customers at Toyota(elderly mostly).
