				Central locking not working
				Posted: Wed Sep 25, 2013 11:45 am
				by BridportBongo
				Hi there (first post)
Just bought an R reg Bongo, with the central locking not working (knowingly).  The seller said that his kids had been playing with the buttons and it just stopped working, so he thought it was just the fuse...
I have replaced fuse 4 and to no effect. I am mostly mechanically incompetent, so does anyone know if I have to do anything after replacing fuse 4  to 'activate' or restart the system.  If not, then can you suggest any alternative solutions, short of taking it to the garage?  I have heard about the door loom, but it does seem in good condition, and would rather not go there unless it is the last resort.
Note, the sliding door still makes the whirry noise when it is closed.
Many thanks
				Re: Central locking not working
				Posted: Wed Sep 25, 2013 1:27 pm
				by Kelvyn
				My door loom looks to be in good condition - however I discovered yesterday with the door fully open, the central locking works - as you close the door it stops working - so I will need to remedy this.
Might be worth trying the central locking with the door at various angles.
				Posted: Wed Sep 25, 2013 2:25 pm
				by helen&tony
The door looms are prone to breaking after years of use. You can strip the outer sheathing off the loom and test to find the broken one and repair it...easily done once the outer sheath is off. just waggle each wire until the offending one works...cut, repair, insulate and sheath the cabling again....but in the long run, it will happen again, with other wires, so the best option is a new loom conveniently available from the club shop. I replaced mine, after years of sticking the door loom back together again and again, and the darned thing always failed in winter
				Posted: Wed Sep 25, 2013 7:28 pm
				by BridportBongo
				Thank you Helen and Kelvyn - clearly this will my job for Sunday!
Sam
				Posted: Thu Sep 26, 2013 12:39 pm
				by ginger colin
				Hi...  mine is intermittent and sometimes only goes half way.  I heard about fuse 4 the 30 amp one part breaking.  does anyone have a pic of what each fuse is.  Cheers
				Posted: Thu Sep 26, 2013 2:54 pm
				Posted: Thu Sep 26, 2013 10:36 pm
				by BridportBongo
				Thanks, I have tried this. I may try the 40a under the bonnet next as well as the loom.
				Posted: Thu Sep 26, 2013 10:52 pm
				The 40 Amp BTN fuse drives half the circuits in the Bongo, if that was blown the Door locks would be the least of your problems!
Look to the Loom, externally it will look perfect!
				Posted: Fri Sep 27, 2013 7:20 am
				by BridportBongo
				Thanks Geoff, very helpful, I'll stay well clear of that as everything else works perfectly
Sam
				Posted: Fri Sep 27, 2013 12:55 pm
				by ginger colin
				Hi many thanks for the pic.
I will try tomorrow...
I noticed they are "Mini fuses"
I didnt realise they have 3 types of fuses now...   Standard, mini and micro fuses
Its the first time I have seen PAL (box shape) fuses as well
Obvious difference Micro fuses dont have tails.
You can get mini fuses that glow red when blown.  they are a lot more expensive than standard minis though.
				Posted: Sat Sep 28, 2013 3:22 pm
				by BridportBongo
				helen&tony wrote:Hi
Thanks Helen, but I can't find it in the shop.. do you know if it comes under another name, or whether it is still available and I am just being a bit blind?
Sam
				Posted: Sat Sep 28, 2013 8:57 pm
				Its under the "Electrics" section 7th item down!
				Posted: Sun Sep 29, 2013 8:22 am
				by BridportBongo
				g8dhe wrote:Its under the "Electrics" section 7th item down!
Ah, 'wiring harness'... Thanks.
