Central locking not working
BridportBongo
Post by BridportBongo » Wed Sep 25, 2013 11:45 am
Hi there (first post)
Just bought an R reg Bongo, with the central locking not working (knowingly). The seller said that his kids had been playing with the buttons and it just stopped working, so he thought it was just the fuse...
I have replaced fuse 4 and to no effect. I am mostly mechanically incompetent, so does anyone know if I have to do anything after replacing fuse 4 to 'activate' or restart the system. If not, then can you suggest any alternative solutions, short of taking it to the garage? I have heard about the door loom, but it does seem in good condition, and would rather not go there unless it is the last resort.
Note, the sliding door still makes the whirry noise when it is closed.
Many thanks
Kelvyn
Re: Central locking not working
Post by Kelvyn » Wed Sep 25, 2013 1:27 pm
My door loom looks to be in good condition - however I discovered yesterday with the door fully open, the central locking works - as you close the door it stops working - so I will need to remedy this.
Might be worth trying the central locking with the door at various angles.
Vehicle Graphics, Signs & Print - http://www.ksdigital.eu
KTM 640 Adventure and Ford Freda
helen&tony
Post by helen&tony » Wed Sep 25, 2013 2:25 pm
The door looms are prone to breaking after years of use. You can strip the outer sheathing off the loom and test to find the broken one and repair it...easily done once the outer sheath is off. just waggle each wire until the offending one works...cut, repair, insulate and sheath the cabling again....but in the long run, it will happen again, with other wires, so the best option is a new loom conveniently available from the club shop. I replaced mine, after years of sticking the door loom back together again and again, and the darned thing always failed in winter :lol:
BridportBongo
Post by BridportBongo » Wed Sep 25, 2013 7:28 pm
Thank you Helen and Kelvyn - clearly this will my job for Sunday!
Sam
ginger colin
Post by ginger colin » Thu Sep 26, 2013 12:39 pm
Hi... mine is intermittent and sometimes only goes half way. I heard about fuse 4 the 30 amp one part breaking. does anyone have a pic of what each fuse is. Cheers
Post by g8dhe » Thu Sep 26, 2013 2:54 pm
BridportBongo
Post by BridportBongo » Thu Sep 26, 2013 10:36 pm
Thanks, I have tried this. I may try the 40a under the bonnet next as well as the loom.
Post by g8dhe » Thu Sep 26, 2013 10:52 pm
The 40 Amp BTN fuse drives half the circuits in the Bongo, if that was blown the Door locks would be the least of your problems!
Look to the Loom, externally it will look perfect!
BridportBongo
Post by BridportBongo » Fri Sep 27, 2013 7:20 am
Thanks Geoff, very helpful, I'll stay well clear of that as everything else works perfectly
Sam
ginger colin
Post by ginger colin » Fri Sep 27, 2013 12:55 pm
Hi many thanks for the pic.
I will try tomorrow...
I noticed they are "Mini fuses"
I didnt realise they have 3 types of fuses now... Standard, mini and micro fuses
Its the first time I have seen PAL (box shape) fuses as well
Obvious difference Micro fuses dont have tails.
You can get mini fuses that glow red when blown. they are a lot more expensive than standard minis though.
BridportBongo
Post by BridportBongo » Sat Sep 28, 2013 3:22 pm
helen&tony wrote:Hi
Thanks Helen, but I can't find it in the shop.. do you know if it comes under another name, or whether it is still available and I am just being a bit blind?
Sam
Post by g8dhe » Sat Sep 28, 2013 8:57 pm
Its under the "Electrics" section 7th item down!
BridportBongo
Post by BridportBongo » Sun Sep 29, 2013 8:22 am
g8dhe wrote:Its under the "Electrics" section 7th item down!
Ah, 'wiring harness'... Thanks.
