battery
Posted: Wed Sep 11, 2013 2:09 pm
by graham8299
hi all, would like to know what sort of reading i should be getting from my leisure battery with an altimeter,got 12.6 on normal battery but leisure battery was only reading 1.2, any info,thanks
Re: battery
Posted: Wed Sep 11, 2013 2:13 pm
by Observer
Hi, is that above sea level? :lol:
Re: battery
Posted: Wed Sep 11, 2013 2:17 pm
If your measuring 1.2 volts with a multi-meter then its really probably only going to be good for the dump!
If its been like it for a while then seriously its dead, if it was charged immediately for a good 48Hours+ on a proper charger, not a small maintenance type one, then it might be recoverable but it will have severely shortened the life of the battery.
Re: battery
Posted: Wed Sep 11, 2013 2:20 pm
by rita
graham8299 wrote:hi all, would like to know what sort of reading i should be getting from my leisure battery with an altimeter,got 12.6 on normal battery but leisure battery was only reading 1.2, any info,thanks
HI, do you mean 12volts if so that should be ok.
If you really mean 1.2 volts you have a problem.
Re: battery
Posted: Wed Sep 11, 2013 3:05 pm
by graham8299
cheers guys,i guess i need a new battery
Re: battery
Posted: Wed Sep 11, 2013 5:12 pm
Do you know why it got so low ?
Re: battery
Posted: Wed Sep 11, 2013 5:32 pm
by graham8299
dont know how it got so low,it may have been like that since i bought it as i have always used the hook up.
Re: battery
Posted: Wed Sep 11, 2013 5:42 pm
by Gasy
Take it down the scrap metal yard
You will get between £5-£10 for it
