battery
graham8299
battery
Post by graham8299 » Wed Sep 11, 2013 2:09 pm
hi all, would like to know what sort of reading i should be getting from my leisure battery with an altimeter,got 12.6 on normal battery but leisure battery was only reading 1.2, any info,thanks
Observer
Re: battery
Post by Observer » Wed Sep 11, 2013 2:13 pm
Hi, is that above sea level? :lol:
My iPhone - My office
Re: battery
Post by g8dhe » Wed Sep 11, 2013 2:17 pm
If your measuring 1.2 volts with a multi-meter then its really probably only going to be good for the dump!
If its been like it for a while then seriously its dead, if it was charged immediately for a good 48Hours+ on a proper charger, not a small maintenance type one, then it might be recoverable but it will have severely shortened the life of the battery.
Re: battery
Post by rita » Wed Sep 11, 2013 2:20 pm
graham8299 wrote:hi all, would like to know what sort of reading i should be getting from my leisure battery with an altimeter,got 12.6 on normal battery but leisure battery was only reading 1.2, any info,thanks
HI, do you mean 12volts if so that should be ok.
If you really mean 1.2 volts you have a problem.
graham8299
Re: battery
Post by graham8299 » Wed Sep 11, 2013 3:05 pm
cheers guys,i guess i need a new battery
Re: battery
Post by g8dhe » Wed Sep 11, 2013 5:12 pm
Do you know why it got so low ?
graham8299
Re: battery
Post by graham8299 » Wed Sep 11, 2013 5:32 pm
dont know how it got so low,it may have been like that since i bought it as i have always used the hook up.
Gasy
Re: battery
Post by Gasy » Wed Sep 11, 2013 5:42 pm
Take it down the scrap metal yard
You will get between £5-£10 for it
