My mechanic says it's running rich "on boost" i.e. the turbo is putting in air but the fuel pump is putting in too much fuel - hence black smoke.
So today (after some instruction), I took the fuel pump diaphragm control out, and turned the toothed wheel anticlockwise by 90 degrees to tighten up the spring, and reduce the amount of movement in the diaphragm - thereby reducing fuel output under load.
So far, it seems to have helped a bit. The other option was to increase boost on the turbo. So my questions are:
1) has anyone tinkered with the fuel pump diaphragm thing?
2) was it successful?
3) has anyone increased boost, and if so what difference did it make?
Cheers !
(PS, I seem to becoming an amateur mechanic this year - what with doing the valve timing and the cam belt myself.)
Thanks to this forum that is !
