Exactly so Dandy and Ferdy, and therein lies the problem.
Because different manufacturers use different methods
to support the load, and these are not always obvious,
you need to be absolutely sure of the facts before you
change from the original wheels to pattern ones either
steel or alloys.
It's true that you can only have one load bearing surface
either the spigot or the wheel nuts. If your original
wheel nuts have a flat mating surface then the spigot
must be the primary load bearing component, these used
to be known as Hub-centric wheels, the nuts (or bolts)
are simply there to stop the wheel falling off.
To confuse the issue, there are also manufacturers who
rely on the spigot as the main load bearing surface, and
therefore the primary centralising method, yet still
use a conical wheel nut to secure the wheel.
There are also manufacturers who rely on the wheel nuts
or bolts to centralise the wheel and provide the main
load bearing surface, the spigot is used to help locate
the centre before fitting the nuts or bolts.
If the designed load bearing surface is the hub spigot, then
it must be necessay to fit spigot rings to oversize spigot
cavities to maintain the original concept.
As a large proportion of Bongos seem to be fitted with
pattern after market wheels, I just think it would be wise
to confirm which is the correct loading surface for the
benefit of those who may not be aware of the implications.
I have searched the forum for specific advice on this
subject but my searching skills are not that great and
it could be tucked away somewhere where I can't find it.
I am not suggesting that there is any danger in fitting
alternative wheels to the Bongo, it's simply that some
wheel balancing problems are a result of inappropriate
matching of the designed vehicle load surface.
I would like to see this debate continue until we reach
a difinitive conclusion with specific regard to the Bongo.
If I had the good fortune to be in Turkey today, I suppose
I could pop in and ask Ron Dennis. (I only wish I could).
