Double Din 'sleeve'
Posted: Tue Aug 27, 2013 10:36 pm
by GreenBongo
I have a MEOS double DIN unit to fit into my Bongo but, having cut out the centre strip, I have found that the unit doesn't fit very well with a gap at the top. In a very old post I have seen a reference to a 'fitting sleeve' but my Google skills are letting me down. Can anyone point me in the correct direction to find one of these? thanks.
Re: Double Din 'sleeve'
Posted: Tue Aug 27, 2013 11:13 pm
by dobby
I haven't used one myself but I'm sure they are called 'double-din cages'. See this search on google:
https://www.google.co.uk/search?q=doubl ... 68&bih=900
Posted: Wed Aug 28, 2013 6:50 pm
by GreenBongo
I've got a cage, I was looking for something that would convert the double DIN plus a little bit to a proper double DIN.
Posted: Fri Aug 30, 2013 9:43 pm
by pc13cb92
Hi, just going through this fitting process, and whilst the cage size is always the same, there are two different fitting sizes, 108mm or 118mm height. Do a search on ebay. The two sizes are referred to as double din and 2 din, ( and they are different). also look up double din fascia plates, as there are differnt sizes in these too.
Posted: Mon Sep 02, 2013 8:38 am
by GreenBongo
Thank you. I'll see what I can find.
Posted: Fri Sep 06, 2013 7:35 pm
by GreenBongo
I found what I was looking for by searching eBay for Double DIN 118mm, the 118mm was the information that I was missing. The new fascia had its clips in the wrong place but I was able to get round that by snapping them off and then gluing it around the old fascia, when fitted you'd never know and I have no gaps now
