Window switch fix (DO NOT DELETE)
salexander
Post by salexander » Thu Aug 22, 2013 11:49 am
I recently had problems with my drivers window switch playing up, obviously not an unusual problem! When I stripped it down I discovered that the switch lever/rocker itself (the bit you push & pull) was worn and allowing it to disengage with the switch itself. The lever/rocker has a hole in each side which engage with matching little spindles on the switch body to form the pivot. These holes were badly worn and elongated, which meant the lever was floating about and not operating the switch properly.
My solution was to remove the lever part and rebuild the missing plastic around the holes using a soldering iron. I used the tip of the iron to carve out some 'blobs' of plastic from the bottom of the switch housing and then fused these to the area around the holes to rebuild the worn bits. You need to make sure the holes end up the right size either by running a drill through them or filing. Also you need to avoid protruding bits of plastic that might stop the lever from rotating cleanly on the switch body.
It only took me ten minutes to sort it out and it seems to be working just fine. I'm guessing that others might have the same problem with their switches and this obviously avoids having to buy an expensive replacement. An alternative would be to buy a cheaper passenger side switch or MX5 switch and swap over the levers I guess.
Photos would have been very helpful, but I didn't think of it at the time :roll:
Re: Window switch fix
Post by Doone » Thu Aug 22, 2013 6:36 pm
No photos, but nice clear instructions. Thanks, a very handy post. =D>
Post by Doone » Thu Aug 22, 2013 7:28 pm
I've added it to a new 'FAQ' on window switches and wiring looms ON THIS LINK If anyone spots another useful post for the FAQ forum, give us a shout and we'll add it.
Post by mikeonb4c » Thu Aug 22, 2013 10:14 pm
Doone wrote:No photos, but nice clear instructions. Thanks, a very handy post. =D>
2nd that. An excellent little tip and just the sort of solution I like to hear. Easy to get the point even without pics. =D>
