Weak heater / aircon blowers.
Had my aircon re-gassed by Nigel of Derbyshire Aircon Services at the Sheffield day meet on Sunday.
It’s blowing out cold now, however my blowers aren't very strong.
They blow and turn up and down on all four settings (Manual air con) so we eliminated the well-documented resistor problem.
The fan you can see if you take the big plastic cover off seems to be spinning ok, but it’s just not very strong in the cab as if something’s blocked up somewhere but couldn't see anything.
We only took the big plastic cover off, and presumably it gets sucked in and through the bits to the left and below?
Any suggestions ?
Cheers.
Jerry.
Any suggestions ?
Cheers.
Jerry.
- mikeWalsall
Re: Weak heater / aircon blowers.
I recently took my under bonnet heating unit off to access the ABS system ..
On checking it over before re fitting I was surprised at the amount of debris stuck on the A/C Matrix and the accumulated dust / crap on the fans 'turbine' ..
Cleaned every thing up with some Mr Muscle kitchen cleaner / water .. then sprayed leckies with some WD40 ..
It as made an amazing difference .. fans is quieter and a far more powerful blow ..
watch out for those large jap dragon flies some are massive, and have big staring eyes.
Ditto. I carefully picked away the remains of the mildewed clogged filter material clogging the matrix. The throughput of the blower increased dramatically, and the tendency to be smelly disappeared.mikeWalsall wrote:I recently took my under bonnet heating unit off to access the ABS system ..
More reading here.... http://igmaynard.co.uk/bongo/forum/view ... lit=gasket
If you scroll down i made a gasket replacement for the evaporator housing which stopped air leaking into the under bonnet compartment, directing it all into the cab....
Thanks chaps, sounds like it's bunged up then.
Ok, now you'll realise what a mechanic I'm not...
Just to clarify, the bit that had the tights put over as a filter, that's the bit over the actual fan that's easily accessible by taking the big plastic bit of that sits on the top.
And...the bit that actually needed cleaning out of insects & muck was the bit that Jaylee is pointing to with his finger in the photos further down, that he made a gasket for.
That right?
And if so, how tricky is it to take off, clean, and more importantly, put back together ??
(after reading the above you may say, for me, very...
Edit:I've looked at the pics in this thread again and can it is the 'other' bit that needs the cleaning, so just need to know how tricky it is.
That right?
Yes.. The intake scoop thing..Jerzy wrote: Just to clarify, the bit that had the tights put over as a filter, that's the bit over the actual fan that's easily accessible by taking the big plastic bit of that sits on the top.
That right?
(after reading the above you may say, for me, very...)
The gasket sits between the fan housing (in front.) joined together to the evaporator housing. (behind) The evaporator is what needs the clean... Air passes through it to the heater housing chamber & then the vents... If the evaporator is clogged then the air flow into the cab is restricted.
I didn't think it was that tricky to remove all the relevant bits.... Cleaning the evaporator fins was the pain for me!! But worth it....
This may help? http://lushprojects.com/bongopartsmk2/c ... mgno=.html
I did the gasket thing also. But I didn't do the tights thing as I didn't have an old pair to hand..........jaylee
Good idea though
Good idea though
Brilliant! Thanks again chaps. I'll get some tights and a rolled up newspaper for the scary suspended-animation dragon flies
Hopefully my next post here won't be "I've got all these bits of plastic on the floor..."
Finally got round to this (Well few weeks ago) using all the tips above.
Actually managed to take it all apart and clean the grill with a toothbrush and the hoover (And no huge dragonflies - I was a *bit* disappointed...)
Here's before:
http://www.youtube.com/watch?v=ADRrfER3hHY
And after:
http://www.youtube.com/watch?v=jMxfd8VGB0Q
Great improvement, thanks for all the tips!
Here's before:
And after:
Excellent, and just in time for the Season of Misty WindscreensJerzy wrote:Finally got round to this (Well few weeks ago) using all the tips above.
Here's before:
And after:
