Tank access hatch
wattg
Tank access hatch
Post by wattg » Mon Aug 05, 2013 7:29 pm
Hi Guys
Having a fuelling issue. The usual misfiring above 2000rpm and under load so did a filter change and banjo strainer clean and was slightly better but still similar symptoms so went back under the drivers seat and collected a hose to the fuel intake to the fuel filter, opened the fuel filler cap and blew air back down the fuel line after a bit of effort felt it give then heard bubbles in the tank. So tried it again and was working fine for a day or two but then symptoms returned. Looks like the fuel uplift strainer is getting clog by crap in the tank. So need to the to the hatch to get at the strainer and see if I can get it cleaned out. So what I am looking for is the exact location of the hatch before I start cutting holes in the plywood floor!?! Any help guys would be much appreciated?
Graeme
wonkanoby
Re: Tank access hatch
Post by wonkanoby » Mon Aug 05, 2013 7:46 pm
might be easier to drop the tank in your case
wattg
Post by wattg » Mon Aug 05, 2013 7:53 pm
How biga job would this be. Any info on doing this?
wonkanoby
Post by wonkanoby » Mon Aug 05, 2013 8:01 pm
wattg
Post by wattg » Mon Aug 05, 2013 8:04 pm
Has anyone dropped the fuel tank down in their bongo and if so how big a job was this??
wonkanoby
Post by wonkanoby » Mon Aug 05, 2013 8:06 pm
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=33920
info there on hose sizes as might be a good idea to change them in your case
wonkanoby
Post by wonkanoby » Mon Aug 05, 2013 8:08 pm
