anyone know what these are called mine are falling to bits,and the gaitor round the shock as this is split.
been having a clonk over bumps when braking
2 years ago new nearside wishbone
1 month ago front and rear anti roll bar bushes,track rod ends,drop links,and off side wishbone
rubber bits at top and bottom of suspention springs
- helen&tony
Re: rubber bits at top and bottom of suspention springs
They are in the diagram here:
http://lushprojects.com/bongopartsmk2/c ... no=.html#5
The bottom one seems to be called a seat, and the top, a sheet
I had mine replaced with the shockers...and I had the bump-stops and bellows done, too.
The rubber inserts make more of a metal-against metal squeak when they disintegrate....
I took the parts to the garage to do....I can't do very much in the cold as was at the time....
chipvan wrote:anyone know what these are called mine are falling to bits,and the gaitor round the shock as this is split.
Upper and lower rubber spring seats....
helen&tony wrote:Hi
The bottom one seems to be called a seat, and the top, a sheetI had mine replaced with the shockers...and I had the bump-stops and bellows done, too.
I took the parts to the garage to do....I can't do very much in the cold as was at the time....![]()
They are just letting you know that the sheet goes to the Top.
Only kidding its a misprint it is a seat.
