Wiring into AFT
onewheeltoofew
Wiring into AFT
Post by onewheeltoofew » Thu Aug 01, 2013 3:44 pm
does anyone know where the wiring for the AFT light comes into the roofspace? I can't see anything obvious along the sides, I assume it's all hidden under the headlining? I really just need the entry point so that I can change the power source and add some connections.
TIA
Re: Wiring into AFT
Post by g8dhe » Thu Aug 01, 2013 8:10 pm
Off side rear are the power leads to the AFT itself, raise the AFT and look at the rear offside hinge and you will see the leads involved.
M2-03 and M2-04.
onewheeltoofew
Re: Wiring into AFT
Post by onewheeltoofew » Thu Aug 01, 2013 8:34 pm
Excellent. Thank you.
