LED interior light bulb replacements
Moderator: Ian
meek.tv
Post by meek.tv » Tue Jul 23, 2013 11:54 pm
It's bee done before but I thought that I would take a few pics and post them up.
I bought a pack of 5 of these...
http://www.ebay.co.uk/itm/111001025172? ... 1497.l2649
they come with a few different fitting options
Rear door/boot door light with the cover off
Springy bit fits different sized festoon bulb holders
I actually ended up taking it back out and tucking the black connector bit underneath the sprung bit first before replacing it all
It is a real tight fit, I had to cut back a bit of the self adhesive pad to get it in ok
all fitted in in nice and snug
The AFT has a shorter bulb but the spring fits fine
You could probably fit a larger one in the AFT if needed but I think it does just fine
If anything they may be a bit too bright when you are slipping out for a pee in the early hours of the morning but they are good for times when you aren't sleeping in the back.
**Edited** bit of a photobucket error
.......... cycling more.
Bongoplod
Re: LED interior light bulb replacements
Post by Bongoplod » Wed Jul 24, 2013 12:03 am
The first link to the lights on ebay works,unfortunately none of the others do :(
Brian
meek.tv
Post by meek.tv » Wed Jul 24, 2013 12:10 am
I had a bit of a photobucket breakdown, should work ok now
Bongoplod
Post by Bongoplod » Wed Jul 24, 2013 12:14 am
Yep,posts fine now,and a good post,might have a crack at them
Brian
meek.tv
Post by meek.tv » Wed Jul 24, 2013 12:17 am
They may fit in the front cab lights too, I haven't had a chance to check yet. I tink somebody here has done it int he past but I'm not sure if they where smaller panels of led than these?
wonkanoby
Post by wonkanoby » Wed Jul 24, 2013 12:32 am
seem to recall my fronts were 24 led like those
meek.tv
Post by meek.tv » Wed Jul 24, 2013 12:59 am
On a related note. Does anybody know the difference between the two ON setting on the aft light switch?
loneranger
Post by loneranger » Wed Jul 24, 2013 6:32 am
Hello I have LEDs in the front and the back lights.The back does take the 24 panel,and the front 2 of the 36 panels.I opted for the blue ones which I find give just as much light as the white ones,but does not affect your night vision.I have had mine in for the last two years,and you may find that some of the LEDs fail over time.As you have either 24 or 36 LEDs one or two failures do not matter.Thanks for the link,I will check to see if they do the Blue ones.Cheers Michael
Red & Blue Advanced Driver "Bongoin in the Peak" or "Aye Up My Duck" Land
meek.tv
Post by meek.tv » Wed Jul 24, 2013 1:47 pm
it's good to know that if one fails on the panel the whole lot doesn't shut down. For the price of them I don't expect them to last forever
meek.tv
Post by meek.tv » Wed Jul 24, 2013 5:07 pm
fronts went in fine
look a bit ugly when they are off but I probably won't notice in a few days. Slightly different colours too :S
loneranger
Post by loneranger » Thu Jul 25, 2013 7:25 am
Hello checked the site and he does not do the blue ones.Also mine are round LEDs about 1/16th inch so do not stand out as much when not lit even though they are the 36 panel ones.Cheers Michael
Return to “Pimp My Bongo”
