Help there coolant everywhere
2manymadmonkeys
- Bongonaut
Can any one help under the drivers door there is a t shape metal connector that has 3 coolant hoses connected to it does anyone know where I can get a new one or know part number and what size clips do I need to buy
Thanks ben
Thanks ben
2manymadmonkeys
- Bongonaut
Re: Help there coolant everywhere
Something like that thanks for link I've not got the skill to make one myself like that
2manymadmonkeys
- Bongonaut
It's a bit dark but there it is its only a small t bit the only bit I can find to buy is really long as in link but can't find a bit like I need
- Muzorewa
Looks like it's been repaired before, and not very well by the look of it. While you've got it stripped down, change the jubilee clips for constant pressure clips like it would have had originally
2manymadmonkeys
- Bongonaut
Any idea what size clips I need and where I can get a t shaped metal joint
- Simon Jones
The trouble is that it has been repaired before so it's more tricky to advise on what parts you may need. If it were me, I'd get a brand new pipe for £70 & rip out all the non-standard parts. See this thread here for more details & links to suppliers:
http://www.igmaynard.co.uk/bongo/forum/ ... ilit=+pipe
2manymadmonkeys
- Bongonaut
Ordered a pipe just waiting for delivery then I need to fit it
poss best to lift either the front or rear quite high, to give room for the twisting/threading through of the new pipe. best to take it out towards the rear.
also take care of the rubber mountings of the nearby pipes as they rip off.
good luck with it, still it could be worse----it could be the other side,-----that one requires the rad out as it will only come out towards the front once you remove everything in its way.
2manymadmonkeys
- Bongonaut
Thanks it's all ready for new pipe now taken every off thats in the way air box pipes etc just waiting for part now
