Hi All, gonna change rear diff oil cannot source
sgl6 limited slip, can only get gl5 limited slip 80/90
will it be okay with this
muny thanks steve
rear diff oil
Re: rear diff oil
LS80W-90 GL-5 is what you are looking for.
Cheers.
Cheers.
Re: rear diff oil
Hi, Got 2 bottles of carlube ls80/90 gl5 was a bit thinner
than what came out
many thanks steve
than what came out
many thanks steve
Re: rear diff oil
Try this: Castrol Syntrax Limited Slip 75w-140.
It completely stopped the hot diff roundabout exit judder and is the only oil that works in my bongo.
Re: rear diff oil
I have been having juddering problems with the LSD [rwd] and have posted (rwd diff problem} about it and the possible
effects of the diff oil.Please could you tell me more about your original problems.I came to the conclusion that the temp of the diff was an issue i.e I only have juddering probs after driving on motorways so I would like to know more about the oil you reccomend and any ideas of why it cures the problem.
