They're drawing more power than the fridge when you turn them up full, but very little when turned down low.
Not bad for £20.
Moderator: Ian
I did - well, the inside edge. It's almost exactly the same depth as the width of the self-adhesive strip. At the top / front of the AFT, I stuck it to the plastic strip up there which doesn't line up with the aluminium, so you end up with a slightly awkward corner, but it sticks well. I've been in all weathers with the top up and down countless times and it hasn't come unstuck yet!onewheeltoofew wrote:Did you just stick them to the front of the aluminium tent extrusion?
At the rear, hinged end of the AFT, there's a small bunch of wires which pops up through the metal floor (beyond the end of the hinged floor with the trapdoor in it) and feed the original light in the centre of the roof.onewheeltoofew wrote:And can you direct me to the hole that the upstairs light? I had a quick look but I couldn't see where the wires come in.
