Abs light code 12
Abs light code 12
My abs light is on and it's coming up with code 12 does anyone know how to fix this problem ?
- mikeWalsall
Re: Abs light code 12
Have you checked for bad multi pin plug connections .. the stop light (brake pedal) switch / wires are OK ... brake lights are working OK .. it does not have LED brake light bulbs ...... ??
- Simon Jones
DemonAV kindly posted the ABS codes, but perhaps there is more than one way to read them as his list does not include 12: http://igmaynard.co.uk/bongo/forum/view ... de#p595919
Or, have you got your code 12 from here?
http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
If so, it could be: 12 - Left front wheel speed sensor or rotor
