First, pop the door capping off inside. The handle is fixed on by a wire circlip, or similar, and this can be revealed by levering the trim round the handle shaft out of the way until you can see the clip to release it. Then , you can pull the door card off, using a broad, thin, flat metal strip , sliding it along until you feel the clip, then it's lever and pop it!
Once the trim's all removed, the rest is quite obvious, with nuts and linkages to undo
When re-assembling, I can't remember which type of trim clip holds the door card on, but they're plastic on most cars, and fit into a keyhole slot...MAKE SURE you line them up by moving them, or you'll break the little beggars when you thump them back in....upon this occuring, flowery language is often heard (LOUDLY)....so make sure small children and animals aren't in the vicinity
Good luck on your mission...any queries, mail me
