about to drill holes bit of info first
Moderator: Ian
Neildeb68
Post by Neildeb68 » Mon Jun 17, 2013 1:27 pm
Hi all before i drill through the centre of the head lining to fit our fold down tv bracket is there any thing behind which needs to be removed? the retaining screws will protrude into the roof under the materess
Re: about to drill holes bit of info first
Post by g8dhe » Mon Jun 17, 2013 2:18 pm
Wiring for the light ? Hope your TV isn't to heavy will the gas supports hold the load ?
Neildeb68
Post by Neildeb68 » Mon Jun 17, 2013 5:18 pm
Geoff it wont be supported by the gas struts just the metal roof inbetween the driver and passenger
Thanks for the reply
Neil
turbodave
Post by turbodave » Mon Jun 17, 2013 7:41 pm
Hi, I have done this and didn't come across any wires , but that doesn't mean that there aren't wires there.....do small holes first and look inside with a torch. Dave
stuc
Post by stuc » Mon Jun 17, 2013 9:58 pm
Thers nothing in there but you can remove the floor inside the roof of the cab(on an AFT) to see the bare roof. Mine has 2 holes in front of this section and 2 underneath this section.
Post by g8dhe » Mon Jun 17, 2013 10:40 pm
No I thought he was putting on the roof board which lifts up!
As far as I know the roof over the cabin is double skinned, once you lift the board out in the AFT you have a ribbed surface, whilst underneath it appears to be smooth when I fitted an extra lamp. There won't be any wires towards the rear, of the existing cab lights.
Post by Simon Jones » Mon Jun 17, 2013 11:41 pm
Be careful drilling thru headlining material as it will catch on the drill bit and end up like spaghetti wrapped around a fork.
If you haven't already got a suitable bracket, drop me a message as I have a spare one of these:
Return to “Pimp My Bongo”
