Printing wiring diagram (members area)
Posted: Thu Jun 13, 2013 4:33 pm
by monein64
Simple question I am sure - Tried to print off demistor / cig lighter wiring diagram (in membewrs area) so I can check areas for faults for below issue, however I can only print part of the diagram or it is to small to take to the Bongo to trace fault.
How do I print off an A4 full size wiring diagram please?
Fault
Rear screen demistor has stopped working, initial checks show that their is no power getting to the screen (with meter), have checked fusesand switch, no problem.
Re: Printing wiring diagram (members area)
Posted: Thu Jun 13, 2013 4:45 pm
by mikexgough
Might be worth checking in the tailgate to body link loom in the top of the door....sometimes cables can snap.... after years of open and shutting....
Posted: Thu Jun 13, 2013 4:52 pm
by monein64
Next place I looked after determining no power on screen and no issue with fuses or switch, should have mentioned this.
spending more time trying to view the diagram on a small screen than finding the fault.
Posted: Thu Jun 13, 2013 8:30 pm
You can do a screen print using the "PrtScr" button and then paste it into your favourite image editor to print it out.
