Printing wiring diagram (members area)
monein64
Post by monein64 » Thu Jun 13, 2013 4:33 pm
Simple question I am sure - Tried to print off demistor / cig lighter wiring diagram (in membewrs area) so I can check areas for faults for below issue, however I can only print part of the diagram or it is to small to take to the Bongo to trace fault.
How do I print off an A4 full size wiring diagram please?
Fault
Rear screen demistor has stopped working, initial checks show that their is no power getting to the screen (with meter), have checked fusesand switch, no problem.
mikexgough
Re: Printing wiring diagram (members area)
Post by mikexgough » Thu Jun 13, 2013 4:45 pm
Might be worth checking in the tailgate to body link loom in the top of the door....sometimes cables can snap.... after years of open and shutting....
monein64
Post by monein64 » Thu Jun 13, 2013 4:52 pm
Next place I looked after determining no power on screen and no issue with fuses or switch, should have mentioned this.
spending more time trying to view the diagram on a small screen than finding the fault.
Post by g8dhe » Thu Jun 13, 2013 8:30 pm
You can do a screen print using the "PrtScr" button and then paste it into your favourite image editor to print it out.
