Front Diff Recurring Problem
STU100
Post by STU100 » Thu Jun 13, 2013 9:43 am
Owned the Bongo for 3 years now - shortly after I got it, humming noise from the front diff. Repaired by seller. Last summer humming diff again and oil leak. Had it inspected and repaired again. Driving on motorway 6 months ago - major diff oil leak. Advised to replace entire front diff unit and driveshafts. Sourced a replacement diff and had it fitted. 3 months ago again on motorway drive shaft inner seal failed - leaking oil. Had this replaced but now the diff is hummming again. Has anyone experienced this before? Is there something that might be causing these recurring problem that I haven't considered? Been suggested that I replace the unit again but am reluctant to do this if going to happen again. Any advice gratefully received.
Re: Front Diff Recurring Problem
Post by rita » Thu Jun 13, 2013 10:01 am
Personally I would convert to 2WD.
What size of front and rear tyres does the vehicle have.
PS if you are going for a repair again you need to get the transfer box Viscous coupling checked out
Post by Bob » Thu Jun 13, 2013 4:29 pm
As Rita says, definitely make sure your tyres are the same rolling circumference.
Good luck.
Post by Northern Bongolow » Thu Jun 13, 2013 9:15 pm
if your wheels and tyres are the correct size etc, do a search on youtube for how to test a viscus coupling. this shows how to hang a weighted bar on a stud to time the drop etc.
on top of the diffs and transfer box there is a breather, they tend to rust up closed. i screw and twist them to free them up. if they cannot breathe they may force oil out of seals or run hot.
