Can you identify a wire for me please?
TerryG
Post by TerryG » Tue Jun 11, 2013 1:23 pm
It's a black insulated wire leading from the driver's side AFT motor and disappearing through/under the driver's side AFT hinge. That particular hinge is caked with rust and I'm worried the wire will suffer. If it's an earth, no prob as i can relocate it. If it's a power feed that's a bit more of a problem as I have a rear kitchen which makes access to the control box somewhat tricky.
Thx in advance.
Terry
'Enjoy every sandwich'
Re: Can you identify a wire for me please?
Post by haydn callow » Tue Jun 11, 2013 1:57 pm
It,s very unlikely a black wire would be power.....generally black is earth....but a few continuity tests should soon prove or otherwise.
Post by g8dhe » Tue Jun 11, 2013 10:38 pm
It sounds like its the earth wire that feeds the switches and lights etc. on the inside top of the AFT connector M2-03 pin A;
