Wheels again
Dave up north
Wheels again
Post by Dave up north » Thu Aug 17, 2006 6:41 pm
Is there a list of the wheels that will fit the Bongo.
I want to ditch that rubbish space saver (after Jane, a friend who has just bought her first bongo last week got a puncture last night, and when she put the space saver on it came off the rim on the first corner, leaving her stranded)
I am wanting a proper spare for me and one for Jane.
Bellhill want ?72 + vat for two steel rims WITHOUT tyres.
Thats going to end up at a hunderd quid each by the time we have put tyres on them.
If there is a list of cars with the same wheels, I can do a trawl of the breakers yards and I bet I can get a couple of wheels a lot cheaper than that.
I know the Ford Probe fits (but the ones I have seen have been alloys. Steel would be better slung under the back)
Any other cars fit?????
Big Dave
dandywarhol
Post by dandywarhol » Thu Aug 17, 2006 8:24 pm
These all have the same hole PCD Dave:
THE WHEEL PCD SIZE IS 5X114.3
THESE FIT THE FOLLOWING CARS
CHRYSLER SEBRING SALOON/COUPE 95>
CHRYSLER NEW YORKER 94>96
CHRYSLER 300 M 98>04
DAEWOO LEGANZA 97>
FORD PROBE 94 > 98
FORD MAVERICK 01>
HONDA HR-V 99>
HYUNDAI SANTA FE 00>
HYUNDAI XG 00>
HYUNDAI COUPE 01>
HYUNDAI TUSCAN 04>
USUZU OASIS 95>
LAND ROVER FREELANDER 97>
LEXUS ES300 92>
LEXUS LS400 91>94
LEXUS GS 300/ 400 93>
LEXUS LS400 94>98
LEXUS RX300 00>03
LEXUS IS 200/300 99>
MAZDA RX7 92>96
MAZDA MX6 92>98
MAZDA XEDOS 6 92>99
MAZDA 626 92>
MAZDA 323 94>98
MAZDA MPV 98>
MAZDA PREMACY 99>03
MAZDA 6 02>
MAZDA 3 03>
MITSUBISHI 3000GT 92>99
MITSUBISHI FTO 96>
MITSUBISHI GALANT 97>03
MITSUBISHI EVOLUTION 1V 96>98
MITSUBISHI EVOLUTION V 98>99
MITSUBISHI VR4 98>02
MITSUBISHI SPACE WAGON 98>
MITSUBISHI GALANT 98>
MITSUBISHI EVOLUTION V1 99>01
MITSUBISHI PININ 00>
MITSUBISHI OUTLANDER 03>
MITSUBISHI GRANDIS 03>
NISSAN SERENA 93>
NISSAN 200 SX 95>
NISSAN MAXIMA / QX 95>
NISSAN ALMERA TINO 00>
NISSAN X TRAIL 01>
NISSAN PRIMERA 02>
NISSAN 300 ZX 95>
PLYMOUTH LASER 94>
PLYMOUTH GRAND VOYAGER 93>
TOYOTA SIENNA 94>
TOYOTA RAV 4 94>
TOYOTA PREVIA 95>
TOYOTA PICNIC 96>
TOYOTA AVENSIS 01>
TOYOTA AVENSIS 03>
TOYOTA PIRIUS 04>
TOYOTA COROLLA 04>
waycar8
Post by waycar8 » Thu Aug 17, 2006 8:31 pm
wow...........THATS A BIG ONE! :shock:
Dave up north
Post by Dave up north » Thu Aug 17, 2006 8:40 pm
Well, thats a start Dandy.
You really COULD have tried harder though
:lol:
Dave up north
Post by Dave up north » Thu Aug 17, 2006 8:42 pm
scuse me for being thick.
Does the list mean that if I find any of the above motors in a scrapyard, the wheels will fit me Bongo. Safe and Secure.
waycar8
Post by waycar8 » Thu Aug 17, 2006 8:46 pm
i think dandy means the rim that fits all those makes and models, the tyres will be different for most.
dandywarhol
Post by dandywarhol » Thu Aug 17, 2006 9:02 pm
The Bongo and all these share the same bolt fixing pattern, you'll need to fit the appropriate nut/bolt to suit - some alloys are spigot mount type (discussed somewhere in a previous thread)
Colin Lambert
Post by Colin Lambert » Thu Aug 17, 2006 11:07 pm
Sorry Dandy but most of these wheels WILL NOT fit because the spigot hole diameter does not match that of the Bongo and the offset is not the same. If the hole is bigger on the bought wheel than the spigot the weight is borne on the studs with the highly likely resultant loss of wheel!
Go to
http://www.alloywheelsinternational.com ... UIDE1.html
and then compare with Bongo wheel size, PCD, offset and spigot hole diameter
white van man
Post by white van man » Thu Aug 17, 2006 11:08 pm
you also have to check the ET (offset) and the load/weight rating of the wheel and tyre as the laden bongo comes in at a hefty2.2 tonnes
dandywarhol
Post by dandywarhol » Thu Aug 17, 2006 11:43 pm
Colin Lambert wrote:Sorry Dandy but most of these wheels WILL NOT fit because the spigot hole diameter does not match that of the Bongo and the offset is not the same. If the hole is bigger on the bought wheel than the spigot the weight is borne on the studs with the highly likely resultant loss of wheel!
Go to
Fair enuffski CL, my 6 week soujourn to warmer climes has obviously boiled my heid a bit...........your fitment guide is heaps better and the spigot advice is essential if the wheel DOESN'T have taper cones where the nut fits (most steel ones do though...)
RobinS
Post by RobinS » Fri Aug 18, 2006 8:35 am
With all the Bongos about having UK Alloys there must be loads of "genuine" steel rims around! When we bought our Bongo from Manchester Campers it had a spacesaver, so asked if it could be changed for a proper wheel - response from Mark - yes I put alloys on them all so I've got a pile of spare wheels - he found one with a good tyre for no extra cost. I would suggest contacting some of the dealers, they have to pay to dispose of the tyres at least if they end up with too many!
Bumbly1
Re: Wheels again
Post by Bumbly1 » Fri Aug 18, 2006 8:46 am
Dave up north wrote:Is there a list of the wheels that will fit the Bongo.
Big Dave
Dave
If you are ever up in Edinburgh, I have a steel wheel with legal tyre you can have f.o.c cant be arsed to send it though :-)
Tom
PS I have fitted Alloys and have used one steel as a spare myself
Bonza
Post by Bonza » Fri Aug 18, 2006 2:02 pm
So, assuming you've found a suitable spare wheel to replace the space saver jobbie what size tyre do you fit? Different front and back so Id go for the rear size reinforced to cover both cases. Should be ok on a 2WD but 4wd who knows.
Wonder what the Bongo would drive like and if its legal?
Bonz
Bumbly1
Post by Bumbly1 » Fri Aug 18, 2006 2:24 pm
Bonza wrote:So, assuming you've found a suitable spare wheel to replace the space saver jobbie what size tyre do you fit? Different front and back so Id go for the rear size reinforced to cover both cases. Should be ok on a 2WD but 4wd who knows.
Bonz
LOL! The space saver is nowhere near the same size as either and the spare is not for prolonged use, merely get you home.
Tom
PS More legal than an abandoned vehicle!
Peg leg Pete
Post by Peg leg Pete » Fri Aug 18, 2006 3:55 pm
I would imagine that if Daves friends tyre came off the rim so easily, it would suggest that the tyre pressure was too low, we had to have almost 60 p.s.i. in our spacesaver, pity you live so far away Tom, would be interested in a wheel myself :wink:
Image Pete
